I'm working on integrating the Ether-Node along with an E6804 into the Helix system.
For some reason the Ether-Node is not linking with the E6804.
So far, I've set the IP on the E6804 to 192.168.10.11. The term jumper for RS-485 comm is set on both the main network controller and the ether-node (3rd and last ID; I have a main board (ID 2) in the middle, the term jumper removed).
I can access the E6804 web page from my laptop, but the Ether-node does not appear to link with it. I've tested my network cables and they're good.
I've also verified I have the correct SD cards are in the correct controllers with their files.
The Ether-Node is showing it has a connection to the network.
I've added the ether-node in HNS 3.2 and setup the E6804 as 192.168.10.11 for the config.
I'm not sure what I'm missing.
Is there any more testing someone can suggest I do to troubleshoot?
I've been thinking of trying to play a short sequence from my laptop, through the E6804. That would be tonight. But, not sure what I can do to test the Ether-node controller.
Sent from my iPhone using Tapatalk
