I recently built a new SS24 board and purchased a board that was already built from a forum member. Before placing them in service I did a thorough check on both boards following the wiki Renard new beginner section and troubleshooting guide, both boards check out good, electrically and diagnostically. However, when I run each board, I can only get the first eight channels to work, channels 9-24 do not respond. I swapped the PIC chips from U6 to U7 to see if channel 9-18 would work but it didn't, however channels 1-8 did, so I know I programmed the PIC's correctly. Next, I double checked the jumper settings since I'm using a USB to serial cable (I know old school) jumper is on JP1, I swapped U4 and U5 chips but no change (I know this goes to the RS485), checked the DM settings for the USB/RS232 cable and made sure they matched in Vixens setting and even updated the driver for the cable, no change. Next, I purchased a new USB/RS232 cable and tried again, no change. Checked all solder joints and reflowed as need, no change.
I'm at a lost, has anyone else had this issue? Your help is appreciated.
Thanks
Thanks
