I have searched the forum for a solution but can't find anything. I have found a lot about flickering lights (turning on when they shouldn't) but not much on them not turning on when they should. I am using an Olson 595 board and the odler version of Vixen (2.1). I have tested all channels prior to setting up the display. But when running my sequences now not all the channels are turning on when they should. What is interesting is that as I've been trying to debug it I can get the channels to turn on if I use the test channels function in Vixen but only under a certain scenario. If I click thgrough each channel individually some channels do not turn on but if I turn all of them on at once the channels that would not turn on now come on.
Any thoughts?
Edit: I am using 64 channels. Channels 1 to 33 are working as expected but channels 33 to 64 exhibit the issue described above. I have also tried vixen 2.5 and 3 and I have the same issue. I'm thinking I have some thing in the plug in set up wrong or com port settings.
Any thoughts?
