it would, just tossing ideas out there.
That's cool, I had considering using a switching supply on a previous project and the barrier was cost. I though perhaps the cost had changed since then.
I support Brian's comment, making the regs run cooler has to be better for reliability.
How does ~$2 for a LM2576-005 and ~$4 for a 100uH 3A inductor, $1 for a 1000uF and 70c for a LM1117-3.3 compare to the overall cost of the finished board?
Adding $8 for a switching reg and a LDO reg or $14 for 2x switching regs is not unreasonable.
Considering these changes would be for a Rev 2 board... has anybody considered using a regulated 5V supply on the input, and anything that requires an AC zero crossing signal can have the required H1 chip onboard?
BTW I expected that some folks might run this board with a 9-12V DC supply, which works w/o any changes. As far as regulator changes and direct access to the 5V rails, I'm open to board changes if they make sense.
Maybe this would be a set of refinements to revisit after the holidays are over and some experience has been gained. Certainly you've made it plenty flexible enough already to implement various power options without board modification.
