beeiilll
Supporting Member
Well being that I have been out of the loop on prototyping and design for quite a few years, I need some help on LED specs.
I am looking at designing an LED light bar to use with plastic blowmolds that will give me multicolors as well as white lighting for the molds. I am considering a bar approx. 2" wide by roughly 24" long that I would insert up into the mold. That way I won't have to cut up the mold on the surface only the bottom would need to be modified.
So my question is what is available out there for max brightness in LEDs now days? I would consider using RGB LEDs if there are any available, but probably I would end up using seperate red, green, blue, and white LEDs to get the max light output from them I would think?
What are the "superflux" LEDs that I have been seeing reference too on here?
Also I am assuming that I would want something with a wide dispersion (say 120 degrees or more), 8mm or larger, and 1 watt or more? Unless I build say 3 seperate sticks and put them in a triangle configuration and then could use LEDs with a smaller dispersion angle? This would give me more brightness overall as well?
Please forgive my lack of knowledge on these as I said I have not been doing design for many years and haven't been following the new things available.
So can anyone "enlighten" me on LED specs and point me in a good direction to learn more about them please?
I guess that I also need to worry about the heat output since this is going into a plastic mold. One LED isn't bad but a lot of them could throw off some heat?
Thank you for any info you can shed on this. I see where you folks on here are building some amazing things and the ideas are great.
Bill Ellick
Bill Ellick
