They loom great! What did you use and how did you do it?
Sent from my SM-G960U using Tapatalk
Are you installing them on the ground? If so how do you support all that weight? Might look good on the house though. I will keep it in mind for a future project. Looks great!
so your telling me ,,you are using grey pvc and the ligh glow trough it ?? m i missing something ??
cheer
Lights need to be super bright type the foggy or duller ones don’t work as good.
Sent from my iPhone using Tapatalk
Have you considered using PEX (also available at HomeDepot) instead of PVC?
I’ve been really happy with the color-transparency (rendering?) of the PEX tubing. I’ve noticed that the PEX tubing is also pretty formable, just by running hot water through it.
I use 1” PEX for my arches and 1/2” for my icicles.
Plan is in the ground ground ... working on trying a few diff options I’ll post what works best soon as I get it right .
I have 3 several candy cane fans made of store bought candy canes that I am considering reworking. They were slammed together quickly with zipties and coroplast base and they are flimsy
Several comments so far:
I like the way yours look and the fact that you can make as many as you want.
I need to test the translucency of PVC.
I like the plywood jig. It took me several closer looks to identify that it was 2 sheets of plywood stacked up. The wood grain lined up so it was difficult to make out the layers.
I need to test the formability of PEX. I know it is translucent, but will it hold a bend after heating and cooling?
