Had to rebuild my FPP master. Somehow it got corrupted. Everything works on it but my 2 remotes running my tune to sign and mega tree aren?t working. They show up on the wireless network.
Sent from my iPhone using Tapatalk
When you deploy stuff using FFP Connect do you deploy to the master and it talks to everyone else or you deploy directly from xLights to each remote?Using ESPs are an inexpensive way to have a pixel port far from your normal network connectivity. I use it on the devices that are on the other side of my driveway. That way I do not need to run a wire up high or protect it from being run over by a car. In general, FPP remotes allow you to significantly limit the traffic on a network while having a lot of pixels in the show. When using FPP remotes, you no longer need to worry about network loading and the lag it causes.
