See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Value of '-2' is not valid for 'Value'. 'Value' should be between 'minimum' and 'maximum'.
Parameter name: Value
at System.Windows.Forms.ScrollBar.set_Value(Int32 value)
at StandardSequence.StandardSequence.m_positionTimer_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase:
file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Vixen
Assembly Version: 2.0.9.0
Win32 Version: 2.0.9.0
CodeBase:
file:///C:/Program%20Files/Vixen/Vixen.exe
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSI....0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
fmod
Assembly Version: 2.0.5.1
Win32 Version: 2.0.5.1
CodeBase:
file:///C:/Program Files/Vixen/fmod.DLL
CometConversion
Assembly Version: 2.0.7.0
Win32 Version: 2.0.7.0
CodeBase:
file:///C:/Program Files/Vixen/AddIns/CometConversion.DLL
DMXAddIn
CodeBase:
file:///C:/Program Files/Vixen/AddIns/DMXAddIn.DLL
MIDIReader
CodeBase:
file:///C:/Program Files/Vixen/AddIns/MIDIReader.DLL
Prop1SeqGen
CodeBase:
file:///C:/Program Files/Vixen/AddIns/Prop1SeqGen.DLL
Prop2SeqGen
CodeBase:
file:///C:/Program Files/Vixen/AddIns/Prop2SeqGen.DLL
RemoteClient
CodeBase:
file:///C:/Program Files/Vixen/AddIns/RemoteClient.DLL
RGBLEDAddIn
CodeBase:
file:///C:/Program Files/Vixen/AddIns/RGBLEDAddIn.DLL
Spectrum
CodeBase:
file:///C:/Program Files/Vixen/AddIns/Spectrum.DLL
WattMeter
CodeBase:
file:///C:/Program Files/Vixen/AddIns/WattMeter.DLL
Waveform
CodeBase:
file:///C:/Program Files/Vixen/AddIns/Waveform.DLL
FrameGenerator
CodeBase:
file:///C:/Program Files/Vixen/Plugins/UI/FrameGenerator.DLL
Frames
CodeBase:
file:///C:/Program Files/Vixen/Plugins/UI/Frames.DLL
LedTriksUI
CodeBase:
file:///C:/Program Files/Vixen/Plugins/UI/LedTriksUI.DLL
StandardScript
CodeBase:
file:///C:/Program Files/Vixen/Plugins/UI/StandardScript.DLL
ScriptEngine
CodeBase:
file:///C:/Program Files/Vixen/ScriptEngine.DLL
StandardSequence
CodeBase:
file:///C:/Program Files/Vixen/Plugins/UI/StandardSequence.DLL
TriggerResponse
Assembly Version: 2.0.8.0
Win32 Version: 2.0.8.0
CodeBase:
file:///C:/Program Files/Vixen/Plugins/UI/TriggerResponse.DLL
AppUpdate
CodeBase:
file:///C:/Program Files/Vixen/AppUpdate.DLL
ICSharpCode.SharpZipLib
Assembly Version: 0.85.1.271
Win32 Version: 0.85.1.271
CodeBase:
file:///C:/Program Files/Vixen/ICSharpCode.SharpZipLib.DLL
System.Configuration
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSI....0__b03f5f7f11d50a3a/System.Configuration.dll
8_Line595
CodeBase:
file:///C:/Program Files/Vixen/Plugins/Output/8_Line595.DLL
AdjustablePreview
CodeBase:
file:///C:/Program Files/Vixen/Plugins/Output/AdjustablePreview.DLL
BasicParallel
CodeBase:
file:///C:/Program Files/Vixen/Plugins/Output/BasicParallel.DLL
DC-16
CodeBase:
file:///C:/Program Files/Vixen/Plugins/Output/DC-16.DLL
DMX-512
CodeBase:
file:///C:/Program Files/Vixen/Plugins/Output/DMX-512.DLL
IDMX
CodeBase:
file:///C:/Program Files/Vixen/Plugins/Output/IDMX.DLL
DMXUSBPro
CodeBase:
file:///C:/Program Files/Vixen/Plugins/Output/DMXUSBPro.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
