Running 1 Renard Controller from F16V3.
rstehle
Active member
I want to run 1 Renard Controller from a Falcon F16V3. I plan to use 8 channels on the Renard for some AC props I still have in my display. I have them set up in my Layout in xlights. My question is about setting up the Serial Output on the F16. Assuming I use output jack #1 on the Falcon to the Renard. (I understand that I have to make a special cable). My question is about setting up the Serial Output correctly on the controller.... Do I set the start channel as the first xlights channel I am using for the AC props? In this case, it would be 21192. Should the channels for the AC props run sequentially? Thanks for any guidance you can provide.
Back
Top
