Scheduler/Show Issue
outbreak
New member
I run 6 shows a night. The same show at the top of the hour that lasts about 55 minutes. It takes 30 seconds to render my sequences.
Every other show doesn't play, but the one before that does. And it's the same exact show, they just start on the top of the hour and end 55 minutes later. I have all of my sequences in "startup" and in sequence, I have a delay of 1.
Does anybody notice anything in this log? Thanks!
Please let me know if you need more/different logs.
11/30/2023 17:00:00.858 [Scheduler] (2023) Show started
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: 30 Seconds.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Pause for 1
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: DONE - National Lampoon.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: DONE - Start New.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: DONE - Rudolph Dubstep.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: DONE - First Noel.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: DONE - Hershey Bells.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: DONE - Wish Liszt.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: DONE - Carol of the Bells Dubstep.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: DONE - Do They Know.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: DONE - It's Beginning to Look.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: DONE - Minions.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: DONE - Hallelujah.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: DONE - Dueling.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: DONE - Light of Christmas.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: DONE - Jingle Bells.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: DONE - Housetop.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: DONE - Let It Snow.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) Pre-processing: Run sequence: Bottom End.tim
11/30/2023 17:00:00.858 [Scheduler] (2023) ExecuteAction: Run sequence: 30 Seconds.tim with state of Running
11/30/2023 17:00:00.858 [Scheduler] (2023) Starting action: Run sequence: 30 Seconds.tim
11/30/2023 17:00:23.628 [Scheduler] (2023) Startup action complete: Run sequence: Bottom End.tim
11/30/2023 17:00:23.628 [Scheduler] (2023) BeginSequential
11/30/2023 17:00:23.628 [Scheduler] (2023) BeginSequential: Enqueue:pause for 1
11/30/2023 17:00:23.628 [Scheduler] (2023) ExecuteNextSequentialItem
11/30/2023 17:00:23.628 [Scheduler] (2023) ExecuteNextSequentialItem: Dequeue next item
11/30/2023 17:00:23.628 [Scheduler] (2023) ExecuteAction: Pause for 1 with state of Running
11/30/2023 17:00:23.628 [Scheduler] (2023) Starting action: Pause for 1
11/30/2023 17:00:24.644 [Scheduler] (2023) Sequential action complete: Pause for 1
11/30/2023 17:00:24.644 [Scheduler] (2023) Shutdown IS requested
11/30/2023 17:00:24.644 [Scheduler] (2023) Starting shutdown
11/30/2023 17:00:24.644 [Scheduler] (2023) Show complete
11/30/2023 17:49:04.845 [Scheduler] Schedule Disabled
The last entries indicate the show is complete and then about 49 minutes later it says schedule is disabled. Was there any manual intervention there? Might need to see your full profile to try to recreate it where I can see more of what is going on.
Sent from my iPhone using Tapatalk
That is where I stopped it because it wasn’t playing. If you look, it pre-processes everything, plays the first sequence then skips to the last sequence.
Cab you post the show setup screens with what is in startup and what is in sequential? Also the actual schedule screen for the times it is scheduled.
I may have figured it out. I think I messed up. For example, I have a show from 7:00 to 8:00, then another show from 8:00 to 9:00. I just changed them to end at 7:59 and 8:59.
That wasn't it.
Back
Top
