Macrosill
Administrator
I had an occurrence scheduled at 10am this morning. I wanted to change it to 11am start instead. Upon changing the time and trying to save it I got this error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Year, Month, and Day parameters describe an un-representable DateTime.
at System.DateTime.DateToTicks(Int32 year, Int32 month, Int32 day)
at Vixen.TimerDialog.PopulateEndTimeValues(DateTime startTime)
at Vixen.TimerDialog.comboBoxStartTime_SelectedIndexChanged(Object sender, EventArgs e)
at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m)
at System.Windows.Forms.ComboBox.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Vixen
Assembly Version: 2.0.9.0
Win32 Version: 2.0.9.0
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/Vixen.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
fmod
Assembly Version: 2.0.5.1
Win32 Version: 2.0.5.1
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/fmod.DLL
CometConversion
Assembly Version: 2.0.7.0
Win32 Version: 2.0.7.0
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/AddIns/CometConversion.DLL
DMXAddIn
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/AddIns/DMXAddIn.DLL
MIDIReader
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/AddIns/MIDIReader.DLL
Prop1SeqGen
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/AddIns/Prop1SeqGen.DLL
Prop2SeqGen
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/AddIns/Prop2SeqGen.DLL
RemoteClient
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/AddIns/RemoteClient.DLL
RGBLEDAddIn
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/AddIns/RGBLEDAddIn.DLL
Spectrum
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/AddIns/Spectrum.DLL
WattMeter
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/AddIns/WattMeter.DLL
Waveform
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/AddIns/Waveform.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Wintrig
Assembly Version: 3.0.0.0
Win32 Version: 3.0.0.0
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/Plugins/Trigger/Wintrig.DLL
FrameGenerator
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/Plugins/UI/FrameGenerator.DLL
Frames
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/Plugins/UI/Frames.DLL
LedTriksUI
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/Plugins/UI/LedTriksUI.DLL
StandardScript
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/Plugins/UI/StandardScript.DLL
ScriptEngine
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/ScriptEngine.DLL
StandardSequence
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/Plugins/UI/StandardSequence.DLL
TriggerResponse
Assembly Version: 2.0.8.0
Win32 Version: 2.0.8.0
CodeBase: file:///C:/Documents%20and%20Settings/Brian/Desktop/Vixen%20Backup%20Files/Vixen%202.0/Plugins/UI/TriggerResponse.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
mscorlib
Vixen
System
System.Drawing
System.Xml
fmod
CometConversion
DMXAddIn
MIDIReader
Prop1SeqGen
Prop2SeqGen
RemoteClient
RGBLEDAddIn
Spectrum
WattMeter
Waveform
Wintrig
FrameGenerator
Frames
LedTriksUI
StandardScript
ScriptEngine
StandardSequence
TriggerResponse
enabled.
For example:
<configuration>
</configuration>
