Wouldn't you want to get done outdoors what you can earlier, though? Could you sequence Remembrance Day poppies on your pixels to justify it?
I've considered a 6 foot poppy mounted to my garage door, never got around to building it.
My entire display has been developed and tweaked over the years and takes about 4 hours to put up and just over 2 hours to take down. My setup has gradual changes that gets added or removed as the years pass.
I will take a few pictures to show my setup and post them over the next few weeks.
-buried in conduit cat-5 runs between house/garage/flagpole
-buried in conduit power lines to breakout posts and gfci outlets
-buried concrete sono-tube bases holding pvc conduit which holds props posts (Pixel poles, and my new North Pole(2022 new prop))
-Flagpole converts to megtree, base ring is segmented octadecagon polygon made with 2 layers of 1x5 pine boards offset to create mounting points to hold together, 8" bungee cords create the tension and spacing for the 32 strands
-Star of Bethlehem sits on an old CB/TV mast mount to the back of my garage and is raised via hand winch
-Arches on collapsible 2x3 stud spacer mounts
-Window frames are aluminum angle stock mounted in windows with eye hooks and zipties
-Pixel-poles (candy poles) tube and pole mount
