DennyMo
New member
You could pick up a DIGWDF SpeedIron -- the one all the DIGWDF engineers use. Get projects done in half the time!
LOL! Nah, I think I'll save up for that DuoHand screwdriver, though. Let us know when they're back in stock.
Looking to upgrade from a 30W pencil to a soldering station. My budget is $100. I assume I should get extra tips when I buy the station. Looking at these two kits, any recommendations for or against? Thanks.
https://www.circuitspecialists.com/CSI-PREMIER-75W-Soldering-Station-Kit.html
https://www.circuitspecialists.com/holiday_gift_pack.html
(Shows as still available, surprisingly...)
I just got one of these.
I just got one of these. I use it with a 5 cell USB power brick for portable use. This iron works really well:
http://www.ebay.com/itm/272227411643
Hmmmm....
I wonder if these irons are static safe? (do they provide ESD protection?)
Read through most of this but it all seemed out of my price range or were discountinued items and dead links. Decide to go with this:https://www.amazon.com/gp/aw/d/B07ZY6LQDV?ref=ppx_pt2_mob_b_prod_image
Any one have experience or opinion about it.
I stand corrected. I have NO Idea why it went out. It just went out.Million's of solder tips are cleaned with a wet Spong, this would have changed if there was an issue. I've seen tip cleaners that actually removed the silver plating on the tip.
I've also been in the profession for 40+ years.
Sent from my Moto Z (2) using Tapatalk
Not sure the key is that it has real temp control. normal that style with temp printed on knob is wattage controled rather than temp think light dimmer. Easy to check if you open it look to see ow manny wires go to iron up 2-3 wires = wattage controled 5-6 = temp controlled.
This is my cheap go new now has real temp control and heats up quick and fits the standard hako tips. https://www.amazon.com/gp/product/B07R4SDSP8/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 or the ts-100 units but thouse are in the $80 range
You can get by with wattage controled but it will ether slow you down or cause you too more easily burn up pads if your inexperienced.
