SSRneon-G2-LED Gerber file
kumpanyman
Supporting Member
I am trying to locate the Gerber files for the SSRneon-G2-LED. I tried downloading using the link on this site but get a message saying
you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Does anyone know how I can gain permission to download the file?
Kumpanyman
Which link are you trying to use? The gerbers are available in the Wiki and I don't remember supporting membership being a requirement to download from the Wiki. There are two versions of the board, one with LEDs and one without (see below). The Gerber link in the G2-LED version does not appear to be funtioning correctly, but the other is working.
@MikeKrebs is correct about being a supporting member to doiyourselfchristmas.com being a great idea! I have to renew my supporting membership at the end of March. The way I see it, I get a whole lot of information from the forum and it's members, so it is only fair to give back to the community.
I did a run of about 25 of the G2-LED boards a couple of years ago to replace all my SSRs, so I do have the G2 gerbers. They are .ger files which are fine if you are ordering from JLCPCB, the file extenstions would need to be modified if ordering from OshPark though.
-Tony
Links to the Wiki:
https://www.doityourselfchristmas.com/wiki/index.php?title=SSRneon-G2-LED#Order_your_own_boards
https://www.doityourselfchristmas.com/wiki/index.php?title=SSRneon#Order_your_own_boards
OK I went to your link, the same link I have tried. I clicked on it.
Order your own boards
You can order your own boards with the information given below, or you can contact: gmbartlett on the DIYC forum to see if he has any in stock.
The PCB industry has a standard for the definition of a PCB. It's called a 'gerber' file. This is a set of files that have the actual instructions that tell the machines how to operate.
The Gerbers for the SSRneon-G2-LED are found at this link: Zip File containing the SSRneon-G2-LED Gerber files
https://www.doityourselfchristmas.c...le containing the SSRneon-G2-LED Gerber files
This is all your should need to order PCBs from any PCB manufacturer.
It says I dont have permission. OK how about this someone down load the gerber file and email it to me at frankbean@yahoo.com
I have become a supporting member. I have downloaded the gerber file and uploaded IT TO JLCPCB. It asks for the board size. What is the board size?
Back
Top
