ho ley crap i order 100 of them and they are still in their box never used ....is that mean i need to go and install them all to test ,,,that is crap big time ,,, if they knew about it they should had send email or put announcement to let us know of the situation/problem ..
cheer
I had a 25% failure rate. I'm not sure what the issue is but mine were sparking from on top the board. I had the first failures replaced. Even some of those had issues so I took some liquid black tape and dabbed around the area where it was sparking. This saved a number of them that were still semi working. I haven't been out in the yard to see how the rest are working. See the attached pic.
I had the same sparking on the initial batch and Todd (DIYLEDExpress) was great and replaced them. If I get any more like this I figured I'd try to fix it like you did (liquid tape or hot glue). But...how did you get it open? The lens appears to be threaded, but I couldn't budge it. Seems glued on solid. Is there a trick? Does it just unscrew if I use enough force? I was sure I would break it so I stopped trying.I had a 25% failure rate. I'm not sure what the issue is but mine were sparking from on top the board. I had the first failures replaced. Even some of those had issues so I took some liquid black tape and dabbed around the area where it was sparking. This saved a number of them that were still semi working. I haven't been out in the yard to see how the rest are working. See the attached pic.
