Ok, that will probably work better. Thanks!Yes - you could also take power to both ends of your arches. Which you're sort of doing anyway if they're next to each other. You can connect power from wherever you want provided the 0v (gnd) is shared between the data signal and the PSU.
Close. If you are injecting in the middle of a string (aka between arces) then the V- you need to worry about is the V- at the pixels at which you are injecting power. That is not (technically speaking) the same V- that you have at the PSU OR the controller. Because current flowing through a wire causes a voltage drop, every inch of wire between any two points in a circuit results in a new/different reference (aka V-) potential. Look at it this way: A controller or a pixel are both data sources. a pixel is a data destination. Each data source has its own V-. The source V- (with as little current through it as possible) needs to go to the V- on the data destination.So black is 0V, needs to be same as your controller 0V. Blue is data (at 5V logic). Red is +5V or +12V probably depending on the pixels you have.
