I have a megatree with somewhat complex and numerous connections to be made (98 of them). I'd like to label the conductors (with alphanumeric text) to reduce the chance of error and make things easier during setup. Last year (first time with this new build) I tried using standard homemade labels (using the typical "Brother" brand label maker). What I found out is that the label wants to return to its flat shape, and unwinds from the conductor. Then they fall off and are lost. I realize that if I had it to do again. I could use the homemade labels, and then cover with clear heat shrink tubing to keep it on. Problem is that at this point I have connectors attached and cannot fit heat shrink tubing over them (either end of the cable).
I was wondering if anyone has come up with a neat approach to this. Color-coding isn't an option since I have more connectors than colors I can distinguish between.
Thanks in advance for any suggestions.
