Just thought I'd throw this onto the interwebs, so when I forget how to get it working, I'll be able to find my own answer...
After frying my T3.2 I decided to try out the T4.1. Since it's so new, I had a hard time finding ready to use code. I was able to get it working this morning, finally. I haven't had a chance to really push it, as you can see, I'm only using 2 pins. The great thing about the 4.1, besides the number of pinouts, is that you can choose which pins, and the pin order you use for the octows2811 library. I'll probably clean up the code and include some additional features over time, but for now, if anyone is struggling to get it working, here is code that seems to work. I'll keep playing with this. Right now, it's based on mrees MegaPixelController, with additional help from the teensy forums to get the built in ethernet to play nice with FastLED FastLED-with-Teensy-4-1-fast-parallel-DMA-output-on-any-pin. I also increased UDP_TX_PACKET_MAX_SIZE to 1500.
Code:
//Running e131 through OctoWS2811 powered by fastled on Teensy 4.1
//Brian Amos <brian@amoscomputing.com>
#include <OctoWS2811.h>
#include <FastLED.h>
#include <NativeEthernet.h>
#include <Arduino.h>
//debug mode adds some serial feedback during testing. Remove this line for production code
#define DEBUG_MODE 1
//DEFINES for at Compile time.
//Leave this alone. At current a full e1.31 frame is 636 bytes..
#define ETHERNET_BUFFER 636 //540 is artnet leave at 636 for e1.31
#define NUM_LEDS_PER_STRIP 340 //170 //680 default
#define NUM_STRIPS 2 //make sure pin list is accurate
#define DMX_SUBNET 0
int unsigned DMX_UNIVERSE = 1; //**Start** universe 1, 9, 17, 25, 33, 41
int unsigned UNIVERSE_COUNT = 4; //How Many Universes 8, 8, 8, 4, 8, 8
int unsigned UNIVERSE_LAST = 4; // List the last universe typically its sequencially from start but does not have to. 8, 16, 24, 28, 32, 40
int unsigned CHANNEL_COUNT = 510; //max channels per dmx packet
byte unsigned LEDS_PER_UNIVERSE = 170; // Max RGB pixels //170 default
int unsigned NUM_LEDS = UNIVERSE_COUNT * LEDS_PER_UNIVERSE; // with current fastLED and OctoWs2811 libraries buffers... do not go higher than this - Runs out of SRAM
//ethernet setup
unsigned char packetBuffer[ETHERNET_BUFFER];
int c = 0;
float fps = 0;
unsigned long currentMillis = 0;
unsigned long previousMillis = 0;
EthernetUDP Udp;
uint8_t mac[6]; //this is determined from the Teensy 4.1 board.
IPAddress ip(192,168,1,10); //static ip address of board
#define UDP_PORT 5568 //E1.31 UDP Port Number
//set up OctoWS2811 and FastLED for Teensy 4.1
const int numPins = NUM_STRIPS;
byte pinList[numPins] = {19, 18};
const int ledsPerStrip = NUM_LEDS_PER_STRIP; //this should be NUM_LEDS / numPins => VERIFY THIS MATCHES THE HARDWARE!! //should also be multiples of a single universe of leds
CRGB rgbarray[numPins * ledsPerStrip];
// These buffers need to be large enough for all the pixels.
// The total number of pixels is "ledsPerStrip * numPins".
// Each pixel needs 3 bytes, so multiply by 3. An "int" is
// 4 bytes, so divide by 4. The array is created using "int"
// so the compiler will align it to 32 bit memory.
DMAMEM int displayMemory[ledsPerStrip * numPins * 3 / 4];
int drawingMemory[ledsPerStrip * numPins * 3 / 4];
OctoWS2811 octo(ledsPerStrip, displayMemory, drawingMemory, WS2811_GRB | WS2811_800kHz, numPins, pinList);
template <EOrder RGB_ORDER = RGB,
uint8_t CHIP = WS2811_800kHz>
class CTeensy4Controller : public CPixelLEDController<RGB_ORDER, 8, 0xFF>
OctoWS2811 *pocto;
public:
CTeensy4Controller(OctoWS2811 *_pocto)
: pocto(_pocto){};
virtual void init() {}
virtual void showPixels(PixelController<RGB_ORDER, 8, 0xFF> &pixels)
uint32_t i = 0;
while (pixels.has(1))
uint8_t r = pixels.loadAndScale0();
uint8_t g = pixels.loadAndScale1();
uint8_t b = pixels.loadAndScale2();
pocto->setPixel(i++, r, g, b);
pixels.stepDithering();
pixels.advanceData();
pocto->show();
CTeensy4Controller<RGB, WS2811_800kHz> *pcontroller;
void setup() {
Serial.begin(115200);
delay(10);
teensyMAC(mac);
static char teensyMac[23];
sprintf(teensyMac, "MAC: %02x:%02x:%02x:%02x:%02x:%02x", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
Serial.print("MAC: ");
Serial.println(teensyMac);
Ethernet.begin(mac, ip);
Serial.print("IP Address: ");
Serial.println(Ethernet.localIP());
Udp.begin(UDP_PORT);
octo.begin();
pcontroller = new CTeensy4Controller<RGB, WS2811_800kHz>(&octo);
FastLED.addLeds(pcontroller, rgbarray, numPins * ledsPerStrip);
FastLED.setBrightness(50);
initTest();
Serial.println("Test Sequence Complete");
} //end setup
static inline void fps2(const int seconds){
// Create static variables so that the code and variables can
// all be declared inside a function
static unsigned long lastMillis;
static unsigned long frameCount;
static unsigned int framesPerSecond;
// It is best if we declare millis() only once
unsigned long now = millis();
frameCount ++;
if (now - lastMillis >= seconds * 1000) {
framesPerSecond = frameCount / seconds;
Serial.print("FPS @ ");
Serial.println(framesPerSecond);
frameCount = 0;
lastMillis = now;
static inline void pixelrefresh(const int syncrefresh){
static unsigned long frametimestart;
static unsigned long frametimeend;
static unsigned long frametimechk;
static unsigned long frameonce;
unsigned long now = micros();
//start frame time
frametimestart = now;
//Serial.println(frametimechk);
//If we have framed no need to frame again update time to most recent
if (syncrefresh == 1){
frametimeend = frametimestart;
frameonce = 1;
//If we havent framed this will increment via time and at some point will be true,
//if so we need to frame to clear out any buffer and the hold off untill
//we receive our next valid dmx packet. We use the pixel protocol to get a general rule of timing to compare to.
frametimechk = frametimestart - frametimeend;
// num leds time 30us + 300us reset to simulate the time it would take to write out pixels.
//this should help us not loop to fast and risk premature framing and jeopordize ethernet buffer
if (frametimechk >= (NUM_LEDS * 30) + 300){
if (frameonce == 1){
octo.show();
Serial.println ("Partial framing detected");
frameonce = 0;
void sacnDMXReceived(unsigned char* pbuff, int count) {
Serial.print("sacn DMX Received: Subnet=");
Serial.print(pbuff[113]);
Serial.print(", Universe=");
Serial.print(pbuff[114]);
Serial.print(", Sequence=");
Serial.println(pbuff[111]);
static unsigned long uniloopcount;
if (count > CHANNEL_COUNT) count = CHANNEL_COUNT;
byte b = pbuff[113]; //DMX Subnet
if ( b == DMX_SUBNET) {
b = pbuff[114]; //DMX Universe
byte s = pbuff[111]; //sequence
static unsigned long ls; // Last Sequence
if (s > ls){
uniloopcount = 0;
ls = s;
//turn framing LED OFF
// digitalWrite(4, HIGH);
// Serial.print("UNI ");
// Serial.println(count );
// Serial.println(s);
if ( b >= DMX_UNIVERSE && b <= UNIVERSE_LAST) {
//Serial.println(b );
if ( pbuff[125] == 0 ) { //start code must be 0
int ledNumber = (b - DMX_UNIVERSE) * LEDS_PER_UNIVERSE;
// sACN packets come in seperate RGB but we have to set each led's RGB value together
// this 'reads ahead' for all 3 colours before moving to the next led.
//Serial.println("*");
for (int i = 126;i < 126+count;i = i + 3){
byte charValueR = pbuff[i];
byte charValueG = pbuff[i+1];
byte charValueB = pbuff[i+2];
octo.setPixel(ledNumber, charValueR,charValueG,charValueB); //RBG GRB
//Serial.println(ledNumber);
ledNumber++;
uniloopcount ++;
Serial.print("UNILOOP");
Serial.println(uniloopcount);
//if (b == UNIVERSE_LAST){
if (uniloopcount >= UNIVERSE_COUNT){
//Turn Framing LED ON
// digitalWrite(4, LOW);
octo.show();
pixelrefresh(1);
uniloopcount = 0;
//Frames Per Second Function fps(every_seconds)
fps2(5);
int checkACNHeaders(unsigned char* messagein, int messagelength) {
//Do some VERY basic checks to see if it's an E1.31 packet.
//Bytes 4 to 12 of an E1.31 Packet contain "ACN-E1.17"
//Only checking for the A and the 7 in the right places as well as 0x10 as the header.
//Technically this is outside of spec and could cause problems but its enough checks for us
//to determine if the packet should be tossed or used.
//This improves the speed of packet processing as well as reducing the memory overhead.
//On an Isolated network this should never be a problem....
if ( messagein[1] == 0x10 && messagein[4] == 0x41 && messagein[12] == 0x37) {
int addresscount = (byte) messagein[123] * 256 + (byte) messagein[124]; // number of values plus start code
return addresscount -1; //Return how many values are in the packet.
return 0;
void initTest() //runs at board boot to make sure pixels are working
LEDS.clear(); //clear led assignments
// LEDS.showColor(CRGB(0,0,0)); //turn off all pixels to start
// delay(500);
LEDS.showColor(CRGB(255, 0, 0)); //turn all pixels on red
delay(3000);
LEDS.showColor(CRGB(0, 255, 0)); //turn all pixels on green
delay(3000);
LEDS.showColor(CRGB(0, 0, 255)); //turn all pixels on blue
delay(3000);
// LEDS.showColor(CRGB(50, 50, 50)); //turn all pixels off
//process dot trace
for (int n=0; n < NUM_LEDS_PER_STRIP*NUM_STRIPS; n++){
octo.setPixel(n,100,0,0);
octo.setPixel(n-2,0,0,0);
octo.show();
delay(10);
octo.setPixel(n,0,100,0);
octo.show();
delay(10);
octo.setPixel(n,0,0,100);
octo.show();
delay(10);
//define mac address of board
void teensyMAC(uint8_t *mac) {
#if defined(HW_OCOTP_MAC1) && defined(HW_OCOTP_MAC0)
Serial.println("using HW_OCOTP_MAC* - see https://forum.pjrc.com/threads/57595-Serial-amp-MAC-Address-Teensy-4-0");
for(uint8_t by=0; by<2; by++) mac[by]=(HW_OCOTP_MAC1 >> ((1-by)*8)) & 0xFF;
for(uint8_t by=0; by<4; by++) mac[by+2]=(HW_OCOTP_MAC0 >> ((3-by)*8)) & 0xFF;
#define MAC_OK
#else
mac[0] = 0x04;
mac[1] = 0xE9;
mac[2] = 0xE5;
uint32_t SN=0;
__disable_irq();
#if defined(HAS_KINETIS_FLASH_FTFA) || defined(HAS_KINETIS_FLASH_FTFL)
Serial.println("using FTFL_FSTAT_FTFA - vis teensyID.h - see https://github.com/sstaub/TeensyID/blob/master/TeensyID.h");
FTFL_FSTAT = FTFL_FSTAT_RDCOLERR | FTFL_FSTAT_ACCERR | FTFL_FSTAT_FPVIOL;
FTFL_FCCOB0 = 0x41;
FTFL_FCCOB1 = 15;
FTFL_FSTAT = FTFL_FSTAT_CCIF;
while (!(FTFL_FSTAT & FTFL_FSTAT_CCIF)) ; // wait
SN = *(uint32_t *)&FTFL_FCCOB7;
#define MAC_OK
#elif defined(HAS_KINETIS_FLASH_FTFE)
Serial.println("using FTFL_FSTAT_FTFE - vis teensyID.h - see https://github.com/sstaub/TeensyID/blob/master/TeensyID.h");
kinetis_hsrun_disable();
*(uint32_t *)&FTFL_FCCOB3 = 0x41070000;
SN = *(uint32_t *)&FTFL_FCCOBB;
kinetis_hsrun_enable();
#define MAC_OK
#endif
__enable_irq();
for(uint8_t by=0; by<3; by++) mac[by+3]=(SN >> ((2-by)*8)) & 0xFF;
#endif
#ifdef MAC_OK
#else
Serial.println("ERROR: could not get MAC");
#endif
void loop() {
//Process packets
int packetSize = Udp.parsePacket(); //Read UDP packet count
if(packetSize){
Serial.println(packetSize);
Udp.read(packetBuffer,ETHERNET_BUFFER); //read UDP packet
int count = checkACNHeaders(packetBuffer, packetSize);
if (count) {
// Serial.print("packet size first ");
// Serial.println(packetSize);
sacnDMXReceived(packetBuffer, count); //process data function
pixelrefresh(0);
