kwoodard
New member
Background - I'm considering making a version of my Arduino Light Controller with on-board SSRs for low-current applications. For instance, my mega tree this year is 32 channels of incandescent strings. Each channel is only 0.34Amps. Next year, I would like to simplify the setup and remove the separate AC SSRs and the CAT5 cabling that connects it all together (this cabling has been a reliability issue for me this year).
I'm also considering making some leaping light arches in the future -- each arch would be 8 channels of either 3 or 4 colors -- this would be perfect for a 32 channel controller with on-board SSRs.
Since I'm only designing this for low current applications, I first considered the VO2223A that is used in the DirkcheapSSRs. Since I like to keep my PCBs as small as possible to keep costs down, I began looking for chips that have multiple channels in the same chip that might use less board space than the VO2223A. I ran across the TLP525G-2 which contains two independent, isolated channels in a 8-pin DIP package. With this chip, I could get twice the board density compared to the VO2223A (1 channel per 8-pin DIP).
So, my question, has anyone used the TLP525G-2 in an AC SSR application or is there technical reasons why this chip would not be a good fit for this application?
Thanks,
Keith
Thanks,
Keith
