Hi everyone,
I am having a problem getting my path correct running my TriksC files...with batch files.
If I create the .bat with no path indicated (see example 1 below) and put it into the directory with my .DAT, LED, and .exe file it works like a charm. See the line from my .bat below:
EXAMPLE 1: ltc09.exe 5min.led #frm #cls tskill ltc09
BUT if I add the actual path (see line from batch below (example 2) including complete path) I simply see a momentary flash of the command prompt window.....but nothing executes and the triksC file does not run....it acts like it doesn't see all the needed files even though they are in the folder.
EXAMPLE 2: C:\Users\Dad\Documents\Vixen\Sequences ltc09.exe 5min.led #frm #cls tskill ltc09
Can someone tell me how to get the complete path to work in my batch file? I need to use the path way due to changes I'm making to the show this year.....in the past I just executed from within the folder as in the first example above and everything was fine.....I can't do that with the current changes and need to go to the path approach.
Thanks for any thoughts...advice..
