Mathissou01
New member
Hello everyone, so I try to control a led strip WS2815 12V with my arduino and everything is correct.
I tried to use vixen to make a light show and found that Vixen is not very powerful and not full of animation like Xlight.
So I tried to use Xlight but I dont know how to connect my Arduino to Xlight.
I found nothing clear , no tutorials that can help me.
I found a code on the "DoItYourself" forum but dont know which pin to put the data on the arduino with this code and what setting to put on Xlight in the controller settings.
Can anyone help me please !
Here the code:
// This code was written by Click that moment.
// To adapt the code to your case, just change this top section, with the #define lines.
// Includes the watchdog timer library
#include <avr/wdt.h>
// This sets how many channels will vixen be sending. Can be set to any number from 1 to 48 for Arduino Mega, and 1 to 18 for Arduino Uno.
#define CHANNEL_COUNT 10
// speed for the com port for talking with vixen. From 9600 to 115200. Use the same speed as set in Vixen.
#define VIXEN_COM_SPEED 57600
// Timeout waiting for serial input before going to random mode (in milliseconds).
#define TIME_OUT 1000
// If the relays turn On and Off opposite to Vixen sequence, change "#define MODE NOT_INVERTED" for "#define MODE INVERTED"
#define NOT_INVERTED 0
#define INVERTED 1
// which pins control which channels
// You can change these assignment to use different pins, but be very careful to not repeat the same pin number for 2 channels.
// DO NOT use pings 0 and 1, as those are for the serial port to talk to the computer.
#define CH01 2
#define CH02 3
#define CH03 4
#define CH04 5
#define CH05 6
#define CH06 7
#define CH07 8
#define CH08 9
#define CH09 10
#define CH10 11
#define CH11 12
#define CH12 13
#define CH13 A0
#define CH14 A1
#define CH15 A2
#define CH16 A3
#define CH17 A4
#define CH18 A5
// Up to here for Arduino uno.
#define CH19 A6
#define CH20 A7
#define CH21 A8
#define CH22 A9
#define CH23 A10
#define CH24 A11
#define CH25 A12
#define CH26 A13
#define CH27 A14
#define CH28 A15
#define CH29 22
#define CH30 23
#define CH31 24
#define CH32 25
#define CH33 26
#define CH34 27
#define CH35 28
#define CH36 29
#define CH37 30
#define CH38 31
#define CH39 32
#define CH40 33
#define CH41 34
#define CH42 35
#define CH43 36
#define CH44 37
#define CH45 38
#define CH46 39
#define CH47 40
#define CH48 41
int channels[] = {CH01, CH02, CH03, CH04, CH05 , CH06, CH07, CH08, CH09,
CH10, CH11, CH12, CH13, CH14, CH15, CH16, CH17, CH18, CH19, CH20, CH21, CH22,
CH23, CH24, CH25, CH26, CH27, CH28, CH29, CH30, CH31, CH32, CH33, CH34, CH35,
CH36, CH37, CH38, CH39, CH40, CH41, CH42, CH43, CH44, CH45, CH46, CH47, CH48
int incomingByte[CHANNEL_COUNT];
int i = 0; // Loop counter
volatile unsigned long timer_a = 0; // new line
//setup the pins/ inputs & outputs
void setup() {
// enable the watchdog timer with a time of 1 second. If the board freezes, it will reset itself after 1 second.
wdt_enable(WDTO_1S);
// specifically for the UNO
sei();
// initalize PWM Channels / Pins
for (i = 0; i < CHANNEL_COUNT; i++) {
pinMode(channels, OUTPUT);
// set all the realys to off to start with
if (MODE == NOT_INVERTED) {
digitalWrite(channels, LOW);
else {
digitalWrite(channels, HIGH);
testSequence();
// set up Serial according to the speed defined above.
Serial.begin(VIXEN_COM_SPEED);
void loop()
if (Serial.available() >= (CHANNEL_COUNT + 2)) {
wdt_reset(); // resets the watchdog
timer_a = millis (); // new line
int uno = Serial.read();
if (uno == 126) {
int dos = Serial.read();
if (dos == 33) {
// read each byte
incomingByte = Serial.read();
int value = incomingByte;
if (value <= 127) {
else {
else {
if (value < 127) {
else {
// Random mode code. Random mode starts if no serial input has been received in TIME_OUT millisenconds
else {
unsigned long diff = millis() - timer_a;
if (diff >= TIME_OUT) {
int random_a = 0;
random_a = random(0, 2);
if (random_a == 0) {
else {
void testSequence() {
delay (500);
else {
delay (500);
Here the code:
#define INVERTED 1
#define CH01 2
#define CH02 3
#define CH03 4
#define CH04 5
#define CH05 6
#define CH06 7
#define CH07 8
#define CH08 9
#define CH09 10
#define CH10 11
#define CH11 12
#define CH12 13
#define CH13 A0
#define CH14 A1
#define CH15 A2
#define CH16 A3
#define CH17 A4
#define CH18 A5
#define CH19 A6
#define CH20 A7
#define CH21 A8
#define CH22 A9
#define CH23 A10
#define CH24 A11
#define CH25 A12
#define CH26 A13
#define CH27 A14
#define CH28 A15
#define CH29 22
#define CH30 23
#define CH31 24
#define CH32 25
#define CH33 26
#define CH34 27
#define CH35 28
#define CH36 29
#define CH37 30
#define CH38 31
#define CH39 32
#define CH40 33
#define CH41 34
#define CH42 35
#define CH43 36
#define CH44 37
#define CH45 38
#define CH46 39
#define CH47 40
#define CH48 41
void setup() {
sei();
else {
testSequence();
void loop()
if (uno == 126) {
if (dos == 33) {
// read each byte
if (value <= 127) {
else {
else {
if (value < 127) {
else {
else {
int random_a = 0;
else {
delay (500);
else {
delay (500);
