chilloutdocdoc
New member
Just put the finishing touches on a very crude Enttec Open DMX Output Module for Vixen 3.0. The module expects you to have the FTDI 2XX driver installed on your computer, and may or may not report an error if you don't have it (haven't bothered to uninstall it myself and see what happens.
I would like to see some others test it out and see where it needs to be improved. Feel free to respond in this thread, or modify the code yourself.
To Use:
1) Extract Zip Contents
2) Copy VixenOpenDMX.dll to the folder filedir/Vixen3.0/Modules/Output/
3) Start Vixen 3.0
Notes if you plan on modifiying/building from source. You will need to change the output directory of the .dll as it is setup on my computer to go right to the vixen modules folder. Yours may or may not be in the same location.
No license on the source, do with it what you will, just please give back to the community if you provide any updates or useful features.
Josh
NOTE/WARNING: This module may or may not be show ready, just like Vixen 3.0. Please test accordingly
Changelog:
V1.0
- Initial Creation
V1.1
- Fixed output value scaling from 0-100 to 0-255
- Fixed memory leak with each write function
- Fixed channels staying at previous value after effect ends
To Use:
3) Start Vixen 3.0
Josh
Changelog:
V1.0
- Initial Creation
V1.1
