jchuchla
Supporting Member
This is a bugfix maintenance release that resolves a handful of bugs users have been reporting. It's considered a safe upgrade.
** Bug
* [VIX-1006] - Open dmx doesn't work on Windows 8 and 10 on 64 build
* [VIX-2238] - If the preview viewer window is minimized when it is closed, then it will restore to a very small toolbar in the upper left corner instead of it's last size.
* [VIX-2239] - If an effect fails to render, it can cause the rest of the effect not to play in the same sample interval because it throws an unhandled exception in the core engine.
* [VIX-2252] - Unhandled exception on startup
* [VIX-2262] - Snow build up is not linked to the snowflake intensity curve.
* [VIX-2263] - Meteor ground level is not linked to the Meteor intensity curve.
** Improvement
* [VIX-2190] - Alternating Default Colors/Icon
* [VIX-2232] - Add the ability to sort elements under a group in the Display setup.
** Bug
** Improvement
