We have released Vixen 3.9 for general consumption.
Release Notes - Vixen 3 - 3.9 Build
** New Feature
* [VIX-988] - Remember Last Loaded Profile
* [VIX-3070] - Create Range Intent to support Moving Heads
* [VIX-3133] - Create DDP output controller
* [VIX-3135] - Add a browser for the Singing Faces Project
* [VIX-3139] - Add Universe export support to DDP module
* [VIX-3147] - Add Fixture Specification Manager to maintain fixture library
** Bug
* [VIX-2586] - Vixen crashes updating Launcher controller to Hide Windows
* [VIX-2962] - Vixen is shutting down every few hours.
* [VIX-3035] - Import Sequence Package Crash
* [VIX-3037] - Extra context menu divider on mark bar
* [VIX-3084] - Picture going up cut disappear before getting all the way to the top
* [VIX-3086] - Lip-sync effect minor bugs and supporting logic need code clean up.
* [VIX-3089] - Add icon to color picker form
* [VIX-3090] - Add icon to color breakdown form
* [VIX-3091] - Resize quick pick color choices on color picker form
* [VIX-3092] - Add icon to color configuration form.
* [VIX-3093] - Add icon to profiles form.
* [VIX-3094] - Add icon to profile name form.
* [VIX-3095] - Specify exact profile you are about to delete.
* [VIX-3098] - Editing Face Mapping colors can cause crash.
* [VIX-3099] - The FastPicture logic in the LipSync effect does not honor the default update interval.
* [VIX-3105] - Import of XModel can produce unexpected results when multiple ranges are specified in the model file.
* [VIX-3107] - Hard crash after importing custom prop and closing the preview with the prop selected.
* [VIX-3108] - XModel import does not properly handle ranges that are reversed.
* [VIX-3109] - Bars Effect rotation default issue
* [VIX-3113] - Bars effect rendering error
* [VIX-3122] - Dimming curve provide incorrect values when placed after the color breakdown filter.
* [VIX-3142] - Unhandled exception when adding new profile
* [VIX-3143] - Liquid effect ctrl copy crashes Vixen
* [VIX-3144] - VIX-3143 Wave Effect could crash Vixen when Ctrl dragging the effect
* [VIX-3151] - Paste as new in Display Setup can crash Vixen.
* [VIX-3164] - Remove extraneous info logging from the sequence grid class.
* [VIX-3172] - Cannot Upgrade tim file using build 1087
** Improvement
* [VIX-3082] - Create HighLowByteFilter to support moving heads with 16 bit control channels
* [VIX-3083] - Add RGBW color support
* [VIX-3100] - Allow Color Property to support more than 8 Discrete Colors
* [VIX-3119] - Message when no elements found when using find selected controllers
* [VIX-3129] - Add a simple function to set an effect to be the entire length of the sequence.
* [VIX-3130] - Ability to adjust all beat bars at the same time
* [VIX-3140] - Extend universe export support to support additional universe types
* [VIX-3148] - Remove redundant Module Type Id and Module Type Instance Id from ModuleStore file.
* [VIX-3155] - Separate the classes in ColorBrekdownModule.cs into separate cs files
* [VIX-3157] - Create Color Wheel Filter
* [VIX-3158] - Create Tagged Filter
* [VIX-3159] - Create Dimmer Filter
* [VIX-3160] - Create Shutter Filter
* [VIX-3163] - Remove version control feature.
* [VIX-3165] - Upgrade Catel to 5.12.10
* [VIX-3178] - Create Named8BitCommand to support Intelligent Fixtures
* [VIX-3182] - Update dependent libraries to the most recent versions.
** New Feature
** Bug
** Improvement
