JEEPGUY
New member
I have been trying to load Vixen on one of my other computers. I am able to successfully load and run Vixen 2.05, however, when I try to load the updates it runs through the updates 2.051 to 2.09, allows me to view the notes and then the Microsoft.net framework pops up and indicates unhandled exception has occurred in your application. Here's the details:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ComponentModel.Win32Exception: This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem
at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at Update.Form1.Form1_FormClosing(Object sender, FormClosingEventArgs e)
at System.Windows.Forms.Form.OnFormClosing(FormClosingEventArgs e)
at System.Windows.Forms.Form.WmClose(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Update
Assembly Version: 2.0.5.1
Win32 Version: 2.0.5.1
CodeBase: file:///C:/Downloads/Vixen 2.0 Release/Vixen 2.0 Release/Update.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSI....0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ICSharpCode.SharpZipLib
Assembly Version: 0.85.1.271
Win32 Version: 0.85.1.271
CodeBase: file:///C:/Downloads/Vixen 2.0 Release/Vixen 2.0 Release/ICSharpCode.SharpZipLib.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSI....0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I have tried 3 times.
I currently running Vixen on the PC I have been programming on without any problems. I am running Win XP on that computer.
I am running Win XP Pro on the one that is my show computer that Vixen won't load correctly. Both are P4's.
Please let me know if you have any suggestions.
mscorlib
Update
System
System.Drawing
System.Xml
enabled.
For example:
<configuration>
</configuration>
