Hey all. Halloween is over so it’s time to tear apart the spider web and make a few mini trees. Just wondering what the advantages/disadvantages are between spiral wiring vs top to bottom strip wiring. Seems spiral wiring would be easier. Does the way you wire them have significant bearing on how you can then sequence them? I’m thinking only 180 degree trees for this year so I can spread the lights a bit further with more trees/props. I learned at Halloween than even one pixel can go a long way in terms of impact if used in the right prop. I had a grouping of five jackolanterns “singing” through the night. Each with just a single triple pixel.
