prof
Member
When the play selection option is used, the selected area disapears when you edit the sequence. I would like to have the ability to apply markers to specify the start and end points of the selection. Markers that stay in place until you cancel them . So that you can edit and replay your changes as many times as required, without having to constantly reselect your selection. (If that makes sense).
Original post (What I would like to see is the ability to chose a section of the sequence and be able to play just that section either once or repeatedly. And have some form of markers to show the start / end points of the section.
I was also thinking of requesting a single step function for manually scrolling through the frames of a sequence, but dropping the playback speed slider down to a few % simulates that).
