BuzzKill
Member
Hi,
Dove in the deep end with DMX this year and will hope to have Halloween blinking and flashing some time this evening.
After several years on the planning table, DMX and Artnet and pixels are back in the spotlight, as I have a significant project on the horizon. Up until now I have still been running Ren24's.
So, it seems while DMX is a standard, implementation from fixture to fixture is decidedly not. Even for a "basic" RGB fixture there can be RGB, RGBW, RGBW +UV, and RGBWA +UV (A=Amber) now as well. The major issue I am running into is that it seems some of these fixtures do not have an option for DMX operation of only RGB or RGBW, and that they use channel 1 as a master dimmer. So, if you add an RGBW element, for example, channel 1 of that element is now the master dimmer, and you then have to mentally transpose RGB to channel 2, 3, 4, and you lose W. One RGB strip I purchased actually has RGBWA +UV (Red, Greeen, Blue, White, Amber, UV). Obviously some of this is on me for not knowing up front what the heck I was purchasing. That is sort of the "price of admission" I suppose. But it would be nice if there were a way to work around these element variations in the element configuration. I am currently running the developer variant of Vixen to take advantage of RGBW. Are there other things coming down the development pipeline to address some the the issues I have described here?
Nice to be active back on the forum again. It has been a few years. I have run Renards for many years, and still do so on a local holiday parade float that has been in service with Renard controllers, running Vixen, since 2010. But I am starting the learning process for converting the entire float to DMX and Artnet driven pixels. My home office floor is covered in DMX Par lamps and about 150' of DMX cables at the moment. Blinken Litez.
Cheers,
Ray
Cheers,
Ray
