Depends at what level do you want to understand how to control the GwtS items. How comfortable are you working with programming code and some very light electronics? The common way of doing this is with an Arduino Uno along with an LED and resistor (and some wires) and using MaterDaddy's library. From there you can send a command to change the colors. After that it gets a little more involved. The main focus of this thread is learning how to integrate them into their Christmas light show so it's about getting timings and such correct and getting your stuff to talk with each other and getting your signal to reach farther. Some people have posted their findings about what certain commands do but some are very guarded about what they find so you may need to do your own research if you want to get deeper into understanding how an effect is done.
Another way to go instead of an Arduino is with a programmable universal remote (like for your tv/media center) but to me that's a little meh and you may have a bit more work getting stuff working right.
Good luck!
Thanks for the reply, you saved me from reading pages of posts
I've been a software developer for 20+ years but mostly C# these days. Since that's in my wheel house I'd like to use either a NetDuino or a Raspberry Pi 2 b with Win 10 on it since I already have both of those.
I'm not a hardware guy per say but can solder and assemble with no problems and have done some breadboarding of stuff.
Is it just a matter of the IR LED's with low resistors to do the transmitting. I was thinking having a receiver would be handy as well where I could use the wand and point it as the receiver and record the commands from it to help figure things out.
But yes ultimatly would like to be able to blast IR from my show to anyone with Disney stuff. Being in Florida the probability of visitors with the stuff is higher then those out of state I would think.
If you could just point me at suitable IR LED and Receiver I should consider the other parts I should be able to figure out from the Netduino forms as well as what as been posted here. Might even take a look at the libarary to see if I can convert it to a .NET version.
I think ultimatly what I would like to see is either Vixen/XLights/FPP be able to send TCP/IP wired/wireless commands to the IR transmitter so that you could easly encorporate it into your show.
