I have built a 16 channel Renard dimmer by joining two 8 channel Renards together.
My problem is as follows.....
The board powers up and I can measure the zero crossing pulse going to the pic, I can measure the crystal freq fine.
When I run vixen with a ramp up the lights go from off to about 3/4 brightness and that is as bright as they get.
I am using the renard-20070812.asm code.
I am also operating with 50hz mains.
If I disconnect the pic from the socket and wire the opto's ground pin to ground the light on the mains side glows brightly, so I know that the opto/triac is working well.
I am using a 3021 opto isolator.
Any help would be absolutely wonderful
Cheers
Daniel
Cheers
Daniel
