Copy/Paste seem to be working fine. Adjustable preview seems to be working fine as well.
But, what doesn't work.. is using the arrow keys when sequencing. Not only can I not move around, but you can't highlight an section, and move around with that section. When you try to hit left or right, it's trying to resize the channel list column size.
Oh.. but if you click into the channel list column, it releases that focus, and the arrow keys work. So, if you highlight a section, click in the channel list column, and then hit the arrow keys, you can move your selection around as it should.
Edit: Maybe I spoke to soon. I was just changing the channel properties (colors) and it appears to have locked up.. 100% cpu till it crashed. I reloaded, changed the colors fine.. saved, started copy/pasting, and it locked/crashed again. So.. it works.. but you have to save often.
I get a lot of these:
fixme:thread:NtQueryInformationThread info class 9 not supported yet
and when it crashed, it ended with this:
fixme:advapi:SetNamedSecurityInfoW L"C:\\windows\\PCHealth\\ErrorRep\\QSignoff" 1 -2147483644 (nil) (nil) 0x13af04 (nil)
err
le:CoGetClassObject class {4e14fba2-2e22-11d1-9964-00c04fbbb345} not registered
err
le:create_server class {4e14fba2-2e22-11d1-9964-00c04fbbb345} not registered
err
le:CoGetClassObject no class object {4e14fba2-2e22-11d1-9964-00c04fbbb345} could be created for context 0x5
Edit some more: Well, I loaded the sequence and set it to loop.. hit the run.. and watched what would happen. Now, on this laptop (again, 900Mhz with 512MB RAM) it is blatantly lagging in the preview. It's still running as I type this without crashing, but the CPU is at 100%.. so I'm guessing it's a horsepower issue for me. Heck, Xorg keeps my machine running at 2 - 11% CPU utilisation under normal load.
Oh.. it doesn't refresh the background window, so I can't seem to stop the sequence now that my browser has been in front of it. When I minimize, I get the preview updating and that's it. :/
