TomL8345
Supporting Member
For the past 10 years, I have been using LED AC Strings with G40 style bulbs on one of my three Mega trees. Another has been LED AC Strings of C9 style bulbs, and the third has been standard 12mm pixels. I really liked the different look of each style of bulb on the three trees, but I wanted to add the versatility of Pixels to the C9 and G40 trees. Earlier this year I started a post on C9 style pixel covers, and I now have nearly completed 3D printing the 500 I need (with help from another member) to complete that project.
Simultaneously, I have been working on a pixel cover to replicate the look of the G40 (round) bulbs. I wanted to be able to use standard 12mm pixel nodes in Boscoyo Pixel Strips. I have come up with an easy to make and relatively inexpensive solution using Clear Vending Machine Capsules.
The capsule that I am using is 2” or 50mm, so these are technically G50 pixel covers. The capsules are 2 pieces Male and Female which snap together to form a 2” transparent sphere.
I made a jig for my drill press to automatically center the female section of the capsule and set my depth stop to the 15/32” part of the step drill.
I then drilled each female half of the capsule.
I then assemble the male and female halves to complete the sphere. This allows the sphere to securely slide over the exposed section of pixels mounted in the pixel strip - I am using 3” spacing.
The capsules are transparent and I wanted a more diffused look so I mounted a 120 grit sanding mop to the drill press and buffed each sphere to a translucent state. This gives me a more even distribution of color without major hotspots.
[video]https://vimeo.com/manage/videos/741918777[/video]
Here is a short video of the results in my workshop. Let me know what questions you may have!
[video]https://vimeo.com/manage/videos/741942710[/video]
Happy Blinky Flashy!
