New Helix V3 Main Board
A quick update. I'm just waiting for a clarification from Macrosill on a potential issue with the Group Buy. As soon as I hear back from him then I'll be able to open it up.
Thank you for your patience.
Greg,
I am ordering the parts to build my V3 Helix and Mouser shows the 583-DB101C (U3) as obsolete. Do you have a recommended replacement for this part?
PM sent for specific questions regarding application to my show requirements. But if I anticipate the answers correctly, I would definitely be in for a board.
Buzz, the group buy was concluded long ago. If you end up wanting a board, contact Greg directly.
I've removed the original schematic, PCB layout and BOM from the initial post and replaced them with a draft assembly manual. There were a couple of errors in the original BOM that are now correct in the assembly manual.
I haven't had the chance to finish the final setup and testing so these areas are blacked out in the manual. I will work on these sections soon and post another update when I get them finished.
IC9 MCP23016 Mouser 579-MCP23016-I/SP 1 is also on backorder. :(
Try Digikey for that one too. I didn't buy anything from Mouser - Digikey were generally cheaper, and for some items, Tayda and Futurlec were a lot cheaper. You have to factor in freight though - I ordered parts for other projects from Tayda and Futurlec, so it wasn't much of an issue for me.
Dave
The MP3 Trigger is back ordered with Sparkfun. I found an alternate supplier. I already had a trigger board. But in case others
need an alternate...
http://microcontrollershop.com/product_info.php?products_id=4524
Unfortunately that item won't work with the Helix. It has a totally different pinout than the BOB-09943, it uses the VS1063 chip instead of the VS1053 and it is designed to host the MP3 songs on the board itself.
This BOB-09943 is a fairly popular product for SparkFun so I would expect them to have them in stock soon.
Soldered everything up this weekend. The guide is absolutely fantastic. I did solder one resistor array in backwards. Rookie move - I got ahead of myself. When I attempted to desolder the part, it cracked. So $6 shipping for a $0.18 part. Live and learn. And I did not add enough of the RJ-45 jacks to the order when I created the BOM on Mouser. So I will get another bunch of goodies this week. I will be driving a REN-24 from the Helix when I get things completed.
Congrats on joining the Helix cult ....errrr....I mean family.:-) I'll be driving two Ren48lsd's, two SS24's, four SS16's, and hopefully my ledtriks with my Helix this year. Greg's done a fantastic job with the Helix, for sure!
I've updated the assembly manual in the first post based on some input I've received. Please use that manual for future assemblies.
Back
Top
