smeighan
Active member
So many of the basic effects can be done with the user defined class. This allows you to write your own effects. I will be teaching (and documenting this) for the academy this weekend. I am going to gather a bunch of them together and make a new basic class. Maybe it will have 20-30 effects in the next month.
Here is a user defined effect (meaning you can type in the php code to generate basic effects). See the bolded line below that creates this flashing color cycle
array_to_save
username f
user_target AA
effect_class user_defined
effect_name USER1
window_degrees 180
start_color #FFFFFF
end_color #FFFFFF
frame_delay 200
sparkles 0
param1 1
param2 2
seq_duration 2
php_program if($frame%4==0) $rgb=hexdec(\"#FFFFFF\"); if($frame%4==1) $rgb=hexdec(\"#FF0000\"); if($frame%4==2) $rgb=hexdec(\"#00FF00\"); if($frame%4==3) $rgb=hexdec(\"#0000FF\");
submit Submit Form to create your effect
OBJECT_NAME user_defined
Here is another example:
array_to_save
username f
user_target AA
effect_name USER7
window_degrees 180
start_color #FFFFFF
end_color #FFFFFF
frame_delay 200
sparkles 0
param1 3
param2 2
seq_duration 2
php_program # function user_defined($frame,$s,$p,$maxFrame,$maxStrand,$maxPixel,$param1,$param2,$start_color,$end_color) $rgb=hexdec(\"#FFFFFF\"); $H=$S=$V=1; $slice=$param1; // use first parameter passed in from user $slice_size=$maxPixel/$slice; $H0 = (($frame% $slice) * $slice_size); $H=($p+$H0)/$maxPixel; if($H>1) $H = $H-intval($H); $rgb=HSV_TO_RGB ($H, $S, $V); return $rgb;
One more. Again, the bolded line is the entire program to create this effect. I will have a document describing how to create your own. The doc will describe the functions available to use.
array_to_save
username f
user_target AA
effect_name USER9
window_degrees 180
start_color #FFFFFF
end_color #FFFFFF
frame_delay 200
sparkles 0
param1 3
param2 2
seq_duration 2
php_program $H = rand(1,100)/100; $S=rand(1,100)/100; $V=rand(1,100)/100; if(($p+$maxFrame-$frame/2)%5==0) { $H=$p/$maxPixel; $S=$V=1; } $rgb=HSV_TO_RGB ($H, $S, $V);
another:
array_to_save
username f
user_target AA
effect_name USER3
window_degrees 180
start_color #FFFFFF
end_color #FFFFFF
frame_delay 100
sparkles 0
param1 1
param2 2
seq_duration 2
php_program $H=$S=$V=0; if($s%2==0) { if($p<=$frame) { $H=$p/$maxPixel; $S=$V=1; } } else if($s%2==1) { if($p>=($maxPixel-$frame)) { $H=1- ($p/$maxPixel); $S=$V=1; } } $rgb=HSV_TO_RGB ($H, $S, $V);
I will probably build 50-100 of these by end of summer and just create them all into the basic effect library.
first, i will get the nutcracker to sync its effects to the music.
array_to_save
username f
user_target AA
effect_name USER1
window_degrees 180
start_color #FFFFFF
end_color #FFFFFF
frame_delay 200
sparkles 0
param1 1
param2 2
seq_duration 2
array_to_save
username f
user_target AA
effect_name USER7
window_degrees 180
start_color #FFFFFF
end_color #FFFFFF
frame_delay 200
sparkles 0
param1 3
param2 2
seq_duration 2
array_to_save
username f
user_target AA
effect_name USER9
window_degrees 180
start_color #FFFFFF
end_color #FFFFFF
frame_delay 200
sparkles 0
param1 3
param2 2
seq_duration 2
another:
array_to_save
username f
user_target AA
effect_name USER3
window_degrees 180
start_color #FFFFFF
end_color #FFFFFF
frame_delay 100
sparkles 0
param1 1
param2 2
seq_duration 2
