My 7th in-progress project is the wire-frame "Merry Christmas" sign with EL wire; I wanted a largish sign outside and over our main front window, one that could be seen form the street - neon was an overkill and way too expensive, and LED strips would not bend properly around the curves I had in mind - I ended up getting some red and green EL wire, red for the "Merry" and green for the "Christmas".
This project is still in the early phase and progress was slow, but the hard work of bending the 6mm wire is now complete.
The general supply list for this project was:
I've yet to spray paint the words black and attach the EL wire, and I've still got to make the wall brace that it will be mounted on, but you get the general idea. The ends of the words will be cleaned up and curled once I have them mounted on the backing frame.
Here's some pictures of the build stages to to date:
This was a once-off project and I don't expect I'll be making more of these wire-frame letter/word signs - I may try my hand at a few small wire-frame reindeer though!
If you need more pictures or information on the build steps let me know.
- 6mm galvanised wire
- EL wire; 5m of each - red and green with 12v input drivers and 1-to-2 splitter cable
- template for the letters bending guide - sourced from MS Word fonts and blown up on a photocopier
- aluminium frame bracing - still to be bought - I expect I'll use a 25mm x 4mm aluminium strap and attach the sign words to this - the sturdy frame can then be attached to the wall with 2 screws/hooks and painted the same colour as the existing wall paint to blend in
- Black spray paint for the letters
- Basic tools included: heavy duty pliers (2 pairs help), bench vise, hammer, bending forms, glue gun, thick gloves for the wire bending process
