I am curious about some specific programming for the pic 688 used in the Renard based Controllers.
My neighbor has two 8 foot diameter "wheels" in his yard. He has white lights around the circumference
of the wheel. There are 8 "Spokes" (from the center), created by four square tubes evenly spaced across the diameter of the ring.
He has green and blue leds alternately installed on the spokes but each color is run across the diameter of the wheel.
So basically he has 4 strands of leds on the wheel. he wants them to "chase" so that it appears the wheel is turning.
I have the Diagnostic pic that tests all the channels in sequence. Could a code be developed using the Diagnostics
program, that would have channels 1-4 turning on in order with about a second in between, and channels 5-8 doing the same?
I could use an 8 channel controller to make both wheels appear to rotate. He doesn't want them sequenced to
the music, just to turn. So the controller with the Pic, programmed in this fashion, could literally be just plugged in
and it would start the channel sequencing and would run all night until powered down.
Next question. Can anyone create a code I can write to the pic, that would do this? I know ZERO about creating
code for the pics. I have looked at .asm files but not sure how to even read them correctly much less edit them.
I hope someone might have time to see if this can be done. I would be willing to pay for your time.
Thanks in advance for any suggestions or assistance!! See attached Pic.
