budude
Supporting Member
No, don't know how to.
Stop the FPP app and run the script (python ./<SCRIPT>.py) with your Triks set up. It's not spectacular, it just prints some lines on the display to verify the addressing and then bales out. If it fails straight off about missing such and such library then look at the first few lines of the script and it will tell you to pull down the particular library. Once you do that, run the script again and it should work. You can play with the data block in the script to create your own pattern if you wish. I created one with all 0's and another with all 1's and alternated them by copying the script function a few times. The command byte contains the panel number in it as well.
