lawn_racer69
New member
Hello, I am trying to reorder my channels in Vixen to match what I actually put up. I have found this to sometimes be easier then trying to go to a certain channel output. This is the way that I have done it for several years, however this year things are not going so well.
I have been trying to order 10 channels for a few hours, i.e. trying to get channel 1 in sequence to energize output 10 on controller. When I go into Vixen 2.1 to rearrange the output, the channels assigned to a particular block change. For example I move channel 4 to coordinate with output 2, but when I go and look channel 4 is actually outputting to 6. There doesn't seem to be much order to it, and there are usually on a few each time that aren't right, but each time I try to reset it, the numbers will all change.
This is kinda a difficult thing to explain via forum. I have attached a output of some data that I was tracking. As you can hopefully see, as I change 1 channel order, there is multiple differences in output. Does anyone have any idea what could be causing this? I am running this on Windows 10, not sure if that would affect it or not. Thanks for any help.
