Well, "apple" is a clue .... and only slightly cryptic!
Dave
Mmmm. It's not a huge deal, I just have to remind myself to switch the default before I go placing the phonemes. I supposed I should go through and do the lyrics for one face all the way through then work on the second but I'm in the habit of working on one chunk of a song at a time, usually in like 1 minute chunks.
I do successfully have two faces singing in a sequence now though, "The Zing" song for the kids![]()
codec101,
I must have been asleep when I read your first post. There is an option on the main LipSync menu which should work for you.
You can place phonemes on the new face using ANY of your available maps. Once finished, select all of the phonemes on the new face and then select "Change Effect Map" in the Lipsync menu. It will change all of the selected maps to the new map you choose. Let me know if this does not work for you.
I would be excited to see "The Zing" song when you have it playing!
Ed
There should be no need for the lip sync functionality to be aware of zig zag hardware layouts. This is one of the reasons for abstracting the elements from the outputs. The elements and preview should be created in a non-zigzag fashion. Management of your hardware layout should be done downstream of your "creation workflow". It can either be done in hardware configuration or in patching, your choice.
--Jon Chuchla--
Sent from my iPhone using Tapatalk
