Ren64TW
Ren64TW - in development.
The Ren64TW is a 64 channel board, using external SSRs. It has an on board power supply, and optional XBee support.
This board is currently in development by J. Bolding (bolwire). An initial run of 10 pcbs has been ordered for testing and verification.
The Board
The board measurement is 5.825"W X 5.500"H, and the provided mounting holes are placed to align with a CG-1500 demarcation enclosure.
Board Availability
The Ren64TW is currently under development and not available at this time.
Bill of Materials
PART NUMBER
(Mouser PN#)
QTY REF NOMENCLATURE
511-L4941BV 1 U1 LDO Voltage Regulators 5.0V 1.0A Positive
534-3517 2 F1 Fuse Clips PC FUSE CLIP 5 MM
534-3527C 1 F1 Vinyl Fuse Cover
504-GMA-1-1/2 1 F1 Cartridge Fuses 250VAC 1.5A Fast Acting
511-1N5817 4 D1-4 Diode Vr/20V Io/1A
291-750-RC 2 R1-2 Resistor - 750ohms 1/4W 5%
291-120-RC 1 R3 Resistor – 120ohms 1/4W 5%
299-1K-RC 2 R4, R7 Resistor – 1K ohms 1/8 W 5%
299-27K-RC 3 R5, R8-9 Resistor – 27k ohms 1/8 W 5%
299-680-RC 2 R6, R10 Resistor – 680 ohms 1/8 W 5%
299-33-RC 1 R11 Resistor – 33 ohms 1/8 W 5%
264-330-RC 1 RN1 Resistor Network 6 pin 330 ohm 1/8 w 2%
838-3FS-412 1 TF1 Power Transformer 12.6VAC CT 6.0VA Single Primary
571-7969492 1 120V N Power Terminal
78-1N5229B 1 D5 Diode, Zener 4.3V .5W
78-1N5239B 1 D6 Diode, Zener 9.1V .5W
78-1N5226B 1 D7 Diode, Zener 3.3V .5W
511-L4931CZ33-AP 1 U14 LDO Voltage Regulators 3.3V 0.25A Positive
571-1-390261-3 8 U6-13 14 Pin IC Socket
571-1-390261-2 2 U4-5 8 Pin IC Socket
571-1-390261-1 1 U2 6 Pin IC Socket
571-5556416-1 19 J1-2, SSR Ports RJ 45 Top Entry
649-10090099-S094VLF 1 JDP1 DB 9 Right Angle
815-ACH-18.432-EK 1 U3 Oscillator
511-ST485BN 2 U4-5 ST485BN
604-WP710A10IT 1 PWR Standard LEDs - Through Hole Red 60mcd 625nm 60 deg Transparent
604-WP710A10GT 6 +5 GND 1 2 3 4 Standard LEDs - Through Hole Grn 60mcd 568nm 34 deg Transparent
782-H11AA1 1 U2 Transistor Output Optocouplers Bi-Directional Input
140-REA332M1CBK1325P 1 C1 Aluminum Electrolytic Capacitors - Leaded 16V 3300uF 20% 12.5x25mm
140-REA470M1CBK0511P 1 C2 Aluminum Electrolytic Capacitors - Leaded 16V 47uF 20% 5x11 mm
80-C322C104K5R 9 C3-11 Multilayer Ceramic Capacitors MLCC - Leaded 50volts 0.1uF 10% X7R
579-PIC16F688-I/P 8 U6-13 8-bit Microcontrollers - MCU 7KB 256 RAM 12 I/O
538-22-03-2021 4 JP1-2 Header 2P
538-22-03-2031 2 JP3-4 Header 3P
151-8000-E 6 Jumpers 2 POS Shunt
532-577102B00 1 U1 Heatsink
M22-7131042 2 Xbee Xbee header
Board Assembly
Jumper Configuration
Test Port
Using the optional XBee support
Schematic Diagram
Setup for Beginners
Trouble Shooting
