SSRez
Wikipedia Encyclopedia
Why Another SSR?
Sean's SSRoz is a very good board. It is compact and functions great and without this inital work, the SSRez may not exist! However, it was not designed with a specific enclosure in mind. The intial move towards the SSRez involved changing the layout to fit the TA-200 Telephone Demarc Enclosure from YourBroadbandStore.com.
In order to keep the board to a min size and the board cost down, the SSRoz has all the neutral connections off board. So, take all the neutrals and connect them with a large wire nut (five 16AWG neutrals!) Once connected, where does the massive chuck of wire go? :) This lead to adding terminals for the neutrals...now this is not inexpensive. The cost was offset in part by removing the vertical fuse holder and replacing it with inexpensive fuse clips.
Lastly, the RJ45 connector could be difficult to remove with the locking pin as the pin ends up in a tight corner. A vertical RJ45 jack made this so much easier.
    Coming Soon
Bill of Materials
[|Mouser BOM]
5      660-CF1/4C681J     1/4Watt Axial Leaded Carbon Film Resistors 680ohms 5% marked R5, R6, R7, R8 and R9
4      660-CF1/4C181J     1/4Watt Axial Leaded Carbon Film Resistors 180ohms 5% marked R1, R2, R3 and R4
4      571-1-390261-1     IC Sockets 6P ECONOMY TIN  (Optional!) also marked U1, U2, U3 and U4
5      538-39890-0302     Eurostyle Terminal Blocks 5.0MM ECONOMY 2P 14-24AWG
    This is a work in Progress!!!
  2. Check your resistors...make sure the part matches whats written on the bag. Every once in a while, the supplier will give you the wrong part. It never hurts to grab a mulitmeter and check those resistors values.
  4. Install the 5 680 Ohm Resistors marked R5, R6, R7, R8 and R9. Bend them first to match the holes (I have been known to bend all my resistors while watching TV!) Insert them through the holes and bend the lead back to about 60 deg on both side to hold them in place. Solder each connection and trim off the excess lead with flush cut snips. Note: Some electronics folks will tell you to do this differently. There is a high specification soldering procedure (typically for military items) that says to cut the leads to length, and then solder them in place. This will work but this level of detail is not required for this board.
  5. Install the 4 180 Ohm Resistors for 120VAC operation or the 330 ohm resistors for 240VAC operation. These are marked R1, R2, R3 and R4. The installation process is the same as in Step #4.
  8. Now its time for the RJ45 Jack. The jack should snap into the 2 large mounting holes and hold itself in place. The pins are very small and solder very fast so be careful not to add too much solder.
  10. The fuse clips are next. Be aware the orientation of these as well. There is a small ridge inside the clip to keep the fuse from sliding out axially. This ridge must go to the side opposite the fuse. Using a fuse to hold the two clips in place while soldering has been suggested.
  11. Last, but not least, the TRIACs. These pins are large and they can be difficult to solder at first. If you have problems...tin the leads prior to inserting them into the boards. Solder the pins in place and trim the excess.
Wiring
    Coming Soon
Early Prototype Picture
