Renard SS8 Controller Board
Revision as of 00:50, 11 January 2010 by Wayne J (talk | contribs) (→‎Fuses: fix BOM link)
The Renard SS8 is a PIC microcontroller based Christmas light controller with 8 solid state relay circuits incorporated into the board. The board design is based on the PIC-based 8-port dimmer concept originally developed by Phil Short. Information on the original concept can be viewed here. Generic information pertaining to current Renard designs (including maximum channel count) can be found on the Renard wiki page.
The Renard Standardized Series (SS) controllers are part of a design effort to standardize the board layouts for Renard based systems and to establish a standardized list of components to use in Renard designs. Some of the goals of the Renard SS design effort were:
  • Completely self-contained controller board. All that is needed to start using the board is a data input and an AC power source. No external DC voltage supply or externally generated ZC is needed and there is no need for an off-board neutral bar.
  • On-board LEDs for full support of Renard diagnostics firmware.
The Board
The Renard SS 8 measures 3.4" X 6"
Circuit Diagram
Key circuit components
Connectors
  • J1 – RS485 outgoing data
  • JDP1 – RS232 incoming data, DE9 connector for direct connect to show computer serial port.
IC Chips
  • U4 & U5 – ST485BN, RS232/RS485 Transmitter/ Receiver
  • U6 – PIC16F688 Microcontroller
  • M1-M8 – MOC3023 Optoisolator, triggers the triac
Resistors
  • R18-25 – Triac gate resistors. The value of these resistors in the BOM was selected for locations using 115/120 VAC power.
Diagnostic LEDs
Other Components
  • T1-T8 – BTA04-700T, these are gate sensitive triacs that only require 5mA of current on the gate signal. They were selected as a dual use triac for both LEDs and regular incandescent lights.
Jumpers
  • JP2 – 120 ohm termination resistor enable. Normally a shunt will be installed on JP2. Remove the shunt if you are experiencing problems with incoming data.
Test Points
  • GND – Ground
  • ZC – Zero Cross signal
The PIC (U6) must be programmed with the latest firmware for the Renard SS8 to operate properly. The firmware can be found on the Renard Firmware wiki page.
Powering the Renard SS8
Input power requirements: An AC source
DC power:
The Renard SS8 generates all the DC voltage that it requires on-board and no external DC voltage source is required.
AC Power:
The Renard SS8 requires AC power for generation of the DC voltage, the SSR (opto/triac) circuitry and for generation of the Zero Cross signal. The information in this wiki is targeted at users who are using 115/120 VAC power.
AC Power Handling Capability
Maximum Input Load
The Renard SS8 has one bank of eight triacs. This bank of triacs is capable of carrying up to 15 amps of current based on the trace width used on the pcb.
Triac Loads
Based on the pcb trace widths, each triac can handle up to two amps of current. A heat sink is highly recommended when running the triacs at two amps. Care must be taken to ensure that the total load of the eight triacs does not exceed the rating of the fuse protecting the triac bank or 15 amps (whichever is less).
The bank of triacs is protected by a fuse. The size of the fuse cannot exceed the current handling capability of the input wire or 15 amps (whichever is less).
The BOM calls for a 10 amp fuse under that assumption that the Renard SS8 will be powered by a common/generic extension cord. Most of the common extension cords used by DIYC members are rated for only 13 amps and 13 amp fuses are not commonly found.
Hooking Up the Renard SS8
Data Connections
Typical connection between computer running Vixen and Renard SS8 boards
Typical connection between RS485/DMX/Renard and Renard SS8 boards
Data Cables
Data cables for Renard SS board hookup directly to computer COMM port
PC DE9 Pin 3 to RJ45-pin 4
Data cable for Renard SS board hookup using a RS232->RS485 converter
Due to the many different types of RS232->RS485 converters available the drawing only refers to the signals coming from the converter. Check the documentation for your converter to figure out how/where to hook up the correct wires.
RS485(-) Signal to RJ45-pin 4
RS485(+) Signal to RJ45-pin 5
Data cable for Renard SS board hookup in a DMX environment
DMX using XLR Connectors
Data cable for Renard SS board hookup to other Renard boards
Cable Lengths
AC Power Connection
  • The size of the fuse cannot exceed the current handling capability of the orange/black wires or 15 amps (whichever is less).
Computer Setup
VIXEN Settings
  • Protocol Version: 1
  • Parity: None
  • Data bits: 8
  • Stop bits: One
If you are unsure that you have built your hardware correctly, you should follow the procedures contained in the Renard SS8 Beginners Setup Guide. These procedures will guide you through the steps to help setup the hardware for the first time.
If you encounter any problems with your Renard SS8, you can go to the Troubleshooting Guide The Renard SS8. The troubleshooting guide contains a methodical process to try to isolate problems/malfunctions and gives suggestions of what to do to fix them.
Beginners Setup Guide The Renard SS8
Assembly Instructions The Renard SS8
Renard Main Page
Renard Firmware
Part Substitutions
VIXEN
Glossary of DIYC Terms
Electronic Symbols
