Vastelec FM02
Revision as of 20:59, 29 September 2011 by Jrd (talk | contribs) (Added some links, moved the first picture up, made the second pic a thumbnail.)
FM-02
FM-02
FM-02b
About VAST Electronics
Vendor's Website
Data Sheet
Detailed Board Dimensions
board dims
board dims
board dims 2
board dims 2
Antenna
smatobnc
smatobnc
How to Make a Dipole Antenna
Setup
http://www.radio-locator.com/
Where can I get one of these wonderful devices ?
