LEDancer
General
The LEDancer (Le Dancer) is an inexpensive controller for up to 56 LEDs with a DMX512 input interface. The LEDs are connected together in a Charlie-Plexed common-cathode configuration. The design needs to use 2N3906 booster transistors for the LED cathodes to ensure that the low-level drive of the PIC is not exceeded, a configuration sometimes called chipi-plexing. The DMX address of the controller can be changed by shunting one of the PIC pins to ground and then sending a specially formatted DMX packet with the desires address.
PCB Schematic
PCB Design
At the moment there isn't a released PCB design. The design consists of a controller board (with a PIC16F1826 and a ST485 RS485 receiver, a jumper for enabling the DMX Address Program Mode, eight resistors and 8 2N3904 transistors, and some connectors.
Here is a proposed sample PCB design (note that it still needs caps next to the Voltage Regulator):
Connector Pinout
Jumper Identification
BOM - Bill Of Materials
538-22-03-2021 | Headers & Wire Housings VERT PCB HDR 2P TIN PLATING | 2 |
538-22-03-2061 | Headers & Wire Housings VERT PCB HDR 6P TIN PLATING | 1 |
538-22-03-2031 | Headers & Wire Housings VERT PCB HDR 3P TIN PLATING | 3 |
80-C322C104K5R | Multilayer Ceramic Capacitors (MLCC) - Leaded 50volts 0.1uF 10% X7R | 1 |
80-C322C334M5U5CA | Multilayer Ceramic Capacitors (MLCC) - Leaded 50volts 0.33uF 20% Z5U | 1 |
299-82-RC | Carbon Film Resistors - Through Hole 82ohms 5% | 8 |
512-2N3904TA | Transistors Bipolar (BJT) NPN Transistor General Purpose | 8 |
511-ST485BN | Buffers & Line Drivers Hi-Spd Lo Pwr Trans | 1 |
579-PIC16F1826-I/P | Microcontrollers (MCU) 3.5KB Flash 256 byte 32 MHz Int. Osc | 1 |
571-1-390261-2 | IC & Component Sockets 8P ECONOMY TIN | 1 |
571-1-390261-5 | IC & Component Sockets 18P ECONOMY TIN | 1 |
604-WP7104GT | Standard LED - Through Hole GREEN TRANSPARENT | 1 |
299-330-RC | Carbon Film Resistors - Through Hole 330ohms 5% | 1 |
LEDs
=BOM==
LED Segment PCBs
LED Connections
THIS SECTION IS OUT OF DATE.
Wirelist
Stackable LED Board Design
Assembly Instructions
PIC Program
Programming the DMX Address
