16 Channel Renard with SSR Assembly Instructions
  • Assembly Time: 2 hours
  • Skill Level: Medium
Disclaimer
THIS FILE IS DISTRIBUTED IN THE HOPE THAT IT WILL BE USEFUL, BUT WITHOUT ANY WARRANTY; WITHOUT EVEN THE IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
Reference Material
Tools
  • Bench Soldering Iron
  • Silver Solder
  • Flat cut dykes
  • Desoldering bulb
Other Requirements
  • You will need an RS232 to RS485 converter. I would suggest EBAY
Related Documents/Links
Build Steps
Install Item Qty Mouser P/N Location Notes
1. IC sockets 6 pin 17 571-3902611 U3-U19 Make sure they are oriented the same way as the silk screen image. U19 is oriented opposite of the others.
2. IC Sockets 8 Pin 2 575-193308 U20 & U21
3. IC Sockets 14 Pin 2 575-199314 U1 & U2
4. Bossman Fuse Holder 4 504-1a3399-10 H1 & H2 pads Make sure the notch on the fuse holder is oriented so one is on the top and the other on the bottom to properly hold the fuse.
5. Euro Sytle Terminal Blocks 11 538-398890-0302 Lower Edge of Board
6. 15Kohm resistors 2 71-ccf60-15k-e3 R17 & R18
7. 178ohm resistors 16 273-178-rc R1 - R16 Orient the colored bands all the same way for ease of troubleshooting later.
8. 10pin 680ohm bus resistor 2 266-680 above U7 & U15
Numbered Photo - Numbers coorospond to the build steps
9. 2 ping jumper mount 4 571-3-644456-2 J1 - J4
10. Green LED 2 604-wp7104gt Ch2Diag #1 & #2
11. Monolithic Radial Capactor 2 81-rpee41h105m4k1e12 C1 & C2
12. Amp Modular Jacks rj45 2 571-5520251-4 Upper Right and Left
13. Coated axial ceramic capacitors 2 80-c410c104m5u C3 & C4
14. Voltage Regulator 1 821-TS7805C2 5vReg
15. 8 amp Triac 16 511-BTA08-400b Bottom of board Be sure to solder these well as they will be carrying 110v A/C
16. 1K ohm resistors 3 660-mf1/4dc1001f R20, R21 & R24
10. 2 11-11 #2
10. 2 11-11 #2
10. 2 11-11 #2
10. 2 11-11 #2
10. 2 11-11 #2
10. 2 11-11 #2
10. 2 11-11 #2
10. 2 11-11 #2
10. 2 11-11 #2
10. 2 11-11 #2
Still Entering Give me so time to finish before you edit this please
Options
220 volt Conversion
