SSRneon-G2-LED
Version G2
Version G2
Safety Features
ne-2E
ne-2E
small
small
1. Dual Neon bulbs that indicate the presence of AC Voltage !
terminal block
terminal block
heat sink
heat sink
TA-200
TA-200
Order your own boards
Home Etch
If you want to home etch an SSR, please go to the wiki entry for the SSRneon-G2 which is a home etch friendly design.
Fuse Rating
fuse
fuse
USE the SSRneon-G2-LED at Your Own Risk !
BOM for 120VAC Operation:
5      604-WP7104IT       LED Standard HI EFF RED TRANS marked LED
1      660-CF1/4C681J     1/4Watt Axial Carbon Film Resistors 680ohms 5% marked R1, R2, R3, R4 & R11
4      660-CF1/4C221J     1/4Watt Axial Carbon Film Resistors 220ohms 5% marked R1, R2, R3, R4 & R11
4      571-1-390261-1     IC Sockets 6P ECONOMY TIN  (Optional, but worth every penny)
                          also marked U1, U2, U3 and U4
5      571-2828372        Terminal Blocks 5.08MM PCB MOUNT 2P
1      504-GMC-8          5mm x 20mm Medium Time Delay Fuses 125VAC 8A Med Time Delay
See above for TA-200 sources.
240VAC Operation
FireGod
Wiring The SSRneon
Controller Output Pinout
Pin Number Connection
1 +5v DC Power
2 Channel 1 Signal
3 reserved
4 Channel 2 Signal
5 reserved
6 Channel 3 Signal
7 Ground
8 Channel 4 Signal
Version G2
Version G2
