Soldering Basics
Soldering quick tips
Soldering Quick Tips
The best solder joints come from a combination of good solder, good tools and practice.
A good solder like Kester 44 (use 63/37 with flux core and 0.032" diameter 1/2lb spool for starters) along with a good temperature controlled soldering like the CSI 1A, CSI 3DLF or the Tenma 21-10115 will result in good solder joints.
It is common to set the iron temperature to 650 - 750 °F for a good joint.
For under $10 you can buy a lot of spare parts and pcbs to practice on listed below
You do not have to clean most flux residue from a soldered joint, but it can help to clean them to see if there are bad joints.
Solder Types
Electronic Solder
  • Lead/Tin solder
  • "Silver" solder
  • Lead-free solder
Lead/Tin
Lead/Tin solder is available in different mixtures of the two metals. There are two popular mixtures available:
*63/37 (Called a eutectic mixture) It contains 63% Tin and 37% Lead and melts exactly at 183 °C (361 °F)
*60/40 Is a common solder that contains 60% Tin and 40% Lead and melts over a range of 183–190 °C (361–374 °F)
They both work fine for electronic work. It is a personal choice as to which you use. The main difference is how they both cool. The 60/40 when cooling goes through a "slushy" phase and does not always result in a bright shiny joint. The 63/37 eutectic solder cools quickly and does not go through the slushy phase. Many people prefer the 63/37 solder, but will use whatever is available when they have it!
Care should be used when handling Lead based solders, you should always wash your hands when you are finished soldering and before eating. In practice there are very low levels of lead and decomposition products from the flux in the smoke from soldering, so it is a good idea to not inhale the smoke. You should also not put the solder in your mouth or chew on it....
"Silver" Solder
Silver solder is similar to Lead/Tin solder, but has a small amount of silver (2-4%) added to it. It is more expensive and is not commonly used for printed circuit board work. It is a specialty solder sometimes used for parts that are already silver plated. The common silver solder eutectic mixture that is 62% Tin/36% Lead/2% Silver melts at 179 °C (354 °F). There is also a "Hard Silver Solder" that has 80%Silver in it and it is used for soldering jewelry and not electronics.
Lead Free Solder
Lead free solder became popular in Europe on July 1, 2006 due to environmental laws associated with eliminating lead. It is generally not recommended for printed circuit board soldering by hobbyists. It is harder to get a good solder joint and is only used by manufacturers using special tools and processes.
Solder Forms
Solder Wire
  • 0.020” popular for fine work and hand soldering Surface mount devices
  • 0.030” used for general soldering of through hole devices
  • 0.040" used for soldering large connectors or very large components like fuse holders
Solder Paste
Bad Solder
Lead Free Solder
Lead Free solder has its roots in Europe due to certain restrictive environmental regulations. It requires greater heat and is noticeably harder to get a good hand soldered joint compared to lead/tin solder. Lead Free solder is often sold right next to regular lead/tin solder in stores, so be careful when you buy your solder. BEGINNERS AND CASUAL USERS SHOULD AVOID LEAD FREE SOLDER. If it is the only solder available, it can be used with caution. For tips on using lead free solder read this article. For tips on repair and rework with lead free solde look here. It generally comes in two compounds Tin/Copper called SnCu or Tin/Silver/Copper (96.5% Tin, 3.0% Silver, 0.5% Copper) called SAC.
Stained Glass Solder
Flux
Soldering Irons
How to select an iron
Temperature Controlled
Low Cost Uncontrolled
Soldering Guns
Soldering Guns
Soldering Tools
Soldering Iron Tips
Wire Cutters
Desoldering
Solder Suckers
Solder Braid
Tweezers
Holders
3rd Hand
Board Holders
Painters Tape
Magnifying Glass
Tip Cleaner
Soldering Iron Stand/ Holder
Electrostatic Discharge (ESD) Mat
Hand Tools
Fume Extractor
Flux Remover
Cleaning Flux residue
http://www.chemtronics.com/c-263-flux-removers.aspx
http://www.mgchemicals.com/products/solder/flux-removers/
How to Solder
Preparation
Iron Temperature
Soldering technique
Common Soldering Problems
Good Guide to soldering problems
How to Desolder
Desoldering
tips
Desoldering Hints
Comparison video of tools
Desolder Braid
Desoldering Wick
http://www.chemtronics.com/descriptions/document/SIZINGGUIDE_LR.pdf
video
Solder Sucker
Solder Sucker
Radio Shack Desoldering Bulb
Radio Shack Spring loaded
Desoldering Pump "SOLDAPULLT"
Desoldering Iron
Radio Shack Desoldering Iron
Hakko 808 Desoldering gun
Circuit Specialists 474A Desoldering station
How To Solder Videos
SMT Soldering Practice Board
How To Solder Guides
Solder and soldering articles
Types of solder
Choosing a soldering iron
Vendors
Hobby KingSoldering irons
Kester Solder Solder
Soldering Practice
Description SKU Quantity
Small StripBoard 94x53mm (Copper) A-5031 2
Big StripBoard 110x93mm (Copper) A-2384 1
Prototyping Board 142x74mm A-5052 1
8 pin DIP IC Socket Adaptor Solder Type A-001 4
14 pin DIP IC Socket Adaptor Solder Type A-004 4
6 pin DIP IC Socket Adaptor Solder Type A-624 4
680 OHM 1/4W 5% Carbon Film Resistor A-2075 20
1K OHM 1/4W 5% Carbon Film Resistor A-624 20
0.1uF 50V Multilayer Monolithic Ceramic Capacitor A-214 5
LED 5mm Red Super Bright A-1554 5
BTA06-600C BTA06-600 Triac 600V 6A BTA06-600C 1
1N4004 Diode 1A 400V A-156 4
DG301 Screw Terminal Block 2 Positions 5mm A-668 3
IRLU024 MOSFET 65 mOhm 17A 55V N-channel I-PAK-3 IRLU024NPBF A-1453 1
LM7805 L7805 7805 Voltage Regulator IC 5V 1.5A A-179 1
40 Pin 2.54mm Single Row Pin Header Strip A-197 1
47uF 16V 105C Radial Electrolytic Capacitor 5x11mm A-4522 5
Threads
Soldering Irons
Desoldering irons
Desoldering tips
Desolder braid
