Soldering Basics
Soldering quick tips
The best solder joints come from a combination of good solder, good tools and practice.
A good solder like Kester 44 (use 63/37 with flux core and 0.032" diameter 1/2lb spool for starters) along with a good temperature controlled soldering like the CSI 1A, CSI 3DLF or the Tenma 21-10115 will result in good solder joints. It is common to set the iron temperature to 650 - 750 °F for a good joint. For under $10 you can buy a lot of spare parts and pcbs to practice on listed below You do not have to clean most flux residue from a soldered joint, but it can help to clean them to see if there are bad joints. Do not attempt to solder circuits that are connected to live power. |
Solder Types
Electronic Solder
- Lead/Tin solder
- "Silver" solder
- Lead-free solder
Lead/Tin
"Silver" Solder
Lead Free Solder
- Lead free solder became popular in Europe on July 1, 2006 due to environmental laws associated with eliminating lead. It is generally not recommended for printed circuit board soldering by hobbyists. It is harder to get a good solder joint and is only used by manufacturers using special tools and processes.
Solder Forms
Solder Wire
Solder Paste
Bad Solder
Lead Free Solder
Lead Free solder has its roots in Europe due to certain restrictive environmental regulations. It requires greater heat and is noticeably harder to get a good hand soldered joint compared to lead/tin solder. Lead Free solder is often sold right next to regular lead/tin solder in stores, so be careful when you buy your solder. BEGINNERS AND CASUAL USERS SHOULD AVOID LEAD FREE SOLDER. If it is the only solder available, it can be used with caution. For tips on using lead free solder read this article. For tips on repair and rework with lead free solde look here. It generally comes in two compounds Tin/Copper called SnCu or Tin/Silver/Copper (96.5% Tin, 3.0% Silver, 0.5% Copper) called SAC.
Stained Glass Solder
Flux
Soldering Irons
Temperature Controlled
Low Cost Uncontrolled
Soldering Guns
Soldering Tools
Soldering Iron Tips
Wire Cutters
Desoldering
Solder Suckers
Solder Braid
Tweezers
Holders
3rd Hand
Board Holders
Painters Tape
Magnifying Glass
Tip Cleaner
Soldering Iron Stand/ Holder
Electrostatic Discharge (ESD) Mat
Hand Tools
Fume Extractor
Flux Remover
http://www.chemtronics.com/c-263-flux-removers.aspx
http://www.mgchemicals.com/products/solder/flux-removers/
How to Solder
Preparation
Clean the PCB and part from heavy dirt / oxidation
Secure the board and attach the part
Preheat the soldering iron
Clean the soldering iron tip
Tin the soldering iron tip
Iron Temperature
Soldering technique
Common Soldering Problems
Good Guide to soldering problems
How to Desolder
Desolder Braid
http://www.chemtronics.com/descriptions/document/SIZINGGUIDE_LR.pdf
Solder Sucker
Desoldering Iron
Circuit Specialists 474A Desoldering station
How To Solder Videos
How To Solder Guides
Solder and soldering articles
Soldering Safety Warnings by Weller
Vendors
Hobby KingSoldering irons
Kester Solder Solder
Soldering Practice
Description | SKU | Quantity |
Small StripBoard 94x53mm (Copper) | A-5031 | 2 |
Big StripBoard 110x93mm (Copper) | A-2384 | 1 |
Prototyping Board 142x74mm | A-5052 | 1 |
8 pin DIP IC Socket Adaptor Solder Type | A-001 | 4 |
14 pin DIP IC Socket Adaptor Solder Type | A-004 | 4 |
6 pin DIP IC Socket Adaptor Solder Type | A-624 | 4 |
680 OHM 1/4W 5% Carbon Film Resistor | A-2075 | 20 |
1K OHM 1/4W 5% Carbon Film Resistor | A-624 | 20 |
0.1uF 50V Multilayer Monolithic Ceramic Capacitor | A-214 | 5 |
LED 5mm Red Super Bright | A-1554 | 5 |
BTA06-600C BTA06-600 Triac 600V 6A | BTA06-600C | 1 |
1N4004 Diode 1A 400V | A-156 | 4 |
DG301 Screw Terminal Block 2 Positions 5mm | A-668 | 3 |
IRLU024 MOSFET 65 mOhm 17A 55V N-channel I-PAK-3 IRLU024NPBF | A-1453 | 1 |
LM7805 L7805 7805 Voltage Regulator IC 5V 1.5A | A-179 | 1 |
40 Pin 2.54mm Single Row Pin Header Strip | A-197 | 1 |
47uF 16V 105C Radial Electrolytic Capacitor 5x11mm | A-4522 | 5 |
