Solid State Relays
A Solid State Relay, or SSR, is an electronic device that uses low voltage input to switch high voltage on or off. It is used in Christmas displays to allow the controller to switch the lights on and off. This article will show one who is not familiar with the device a basic overview of how it works.
Here is a link to a schematic of the Sean Bowf/John Wilson design.
http://christmasinshirley.com/wiki/images/0/04/SSROZ25b_schematic.pdf
Components
There are a few basic components that make up a Solid State Relay.
Triac
Optocoupler
Fuse
Resistors
