Vastelec FM02
Revision as of 19:03, 29 September 2011 by Ukewarrior (talk | contribs)
FM-02
FM-02
FM-02
FM-02
About VAST Electronics
Vendor's Website
Data Sheet
Detailed Board Dimensions
board dims
board dims
board dims 2
board dims 2
Antenna
smatobnc
smatobnc
Setup
http://www.radio-locator.com/
Where can I get one of these wonderful devices ?
They may also be available at WLC ventures.
They have also been seen for sale on ebay.
